jos51700
Green Bearing thread connoisseur
I see a waste of time in the shape of fan shroud that doesn't even fit the blade or seal to the radiator.... You're probably pulling more air through the gap at the top than you are through folded fins on that radiator.What kind of drugs are you on. I would like some of those. if you look back on post #1, you might see a shroud, or maybe not.
But you're right, there's a shroud there. Next time just lay it on top of the motor and close the hood. It'll do as much good.
