Any recommendations for crimping tools for these? Thanks
These are what I use with success. https://www.amazon.com/gp/product/B0045CUMLQ/?tag=fabo03-20
Good question. Probably should have posted a link or two about the crimpers and crimping.Any recommendations for crimping tools for these? Thanks
This thread has turned into quite the resource. I'm currently going thru another ignition switch on a Mopar (Duster this time). Last time I bought all the pieces to build a weatherpack connector which worked, but will not slide thru the column for future replacement. This time I'm just wanting to rebuild the OE connector.
What type of terminals are these? I've gone thru a bunch of pictures on google images and have yet to find one. Sorry for the bad pic,
Lots of good info in this thread, I'm redoing my 67 rally harness here.
Rally dash redo
More good info, I believe try molex as a term?
I am reusing all connectors like those by splicing/soldering.
Really they are 58? Always use 56!="Mattax, post: 1972250265, member: 29156"]I already have a collection of 56 series. Waytek Wire had min purchases, so I bought terminals by the bagful about 20 yrs ago.
Now I'm looking to build a collection of Chrysler types.
Looks like most are the same as some Ford and GM 'Packard 58'.
Standard lists the tin-plated brass female terminals as CG49 for 16-14 ga, and CG36 for
20-18 ga packages of 10. Chrysler part number 384601 regardless of wire size.
Eastern Beaver linked above has the wider 3/16" terminals, like used on the headlights, but not plated. The originals on my '67 were plated.
They also have crimps for splicing. That's handy, even if soldering.
Bought this removal tool kit on flea bay works great so far. Does most styles.
Glad those look like they will work.
@Thanatos340 found the Molexes he bought were a little loose in the turn signal housing and was going to try Mate-N-Loks
see this post What are these Connectors called??
I don't know what he found out.
As long as the terminals mate to each other, I think that's more important than how snug they are in the plastic.
The only thing about being loose in the housing is if the terminals back out rather than mate.
I had that with a GM SI type alternator connector as well as on the Ford type coil connector on my Jeep. Push on the connector and the terminal backs out but is engaged just enough to sort of work. Finally figured it out when back probing.
I love using their wire. They have multiple sizes and striped wire. Just got done with my dash harness using their wire.I bought this when I did my upgrades along with other wires I sourced out.
100 FEET AUTOMOTIVE PRIMARY WIRE 14 GAUGE AWG HIGH TEMP GXL 10 COLORS 10 FT EA | eBay
I don't specifically recall. By the time I bought the terminals specifically made for two side by side wires, I had already purchased the copy of the Packard crimper for them.So one of the terminals that there are only a few of on our mopar's are these double wire terminals.
I recently re-did the dual ballast wiring on a 75 Duster 360 and that happens to be one of the spots these terminals are used.
I do have some new double terminal terminals I've purchased, but using the ASTRO 9477 do any fello FABO BrainTrust members know where I could get the correct die's for my crimper that work with these or if such a thing exists?
