I have a 71 Duster 225ci and when I start the car, the starter grinds occasionally. Sometimes it will do it right away, sometimes for a split second while cranking, and others not at all. The fact that it is intermittent and not constant makes it odd. Or is that normal? What would cause this? I would assume the gears are not lining up, but is it possible to adjust this? Thanks in advance.
