Stop in for a cup of coffee
Crimp a terminal for the starter relay to a wire . Crimp either a ring terminal or attach an aligator clip to the other end.
Either attach it to ground with a screw
or
leave it in the glove box and put it on when you need it and remove after starting.
easy peasy
Just did a service on a 15 f150.
Ecoboost.
Oil drain plug is some stupid plastic bit that you turn with a 3/8” drive. And oil gushes out like a torrential downpour.
What a freakin mess! Not to mention you have to unbolt some kind of insulation pad.
Guess its there to soak up the oil when that stupid plug fails. Must be a diaper.
O rings on filter housing, one so small its impossible to replace without stretching it with some sort of tool. Pita!
8 litres of oil! 2.7 litre engine wtf??
My shop is pretty well lit,still need a light to see the dipstick hole, its deep in a shadow. And a step as its too far to reach.
Fn engineers...
Rant over.
Definitely buying back the 66 from Dave. Will be a fun time in July. AND a 408 stroker is probably going into in.......Need a 727 for it......
Ecoboost.
Fn engineers...
Rant over.
Ford seems to be the worst.
Nope. a well built 904 is the trick. No need to clobber the transmission tunnel to get the 727 to fit.
Yes. Need to ordinate a lot of things with a few people, BUT I am thinking it can be pulled at Rays, Hoppy, in PA before/after Carlisle event. BUT not confirmed with anyone yet on anything.....
sounds like a party. Hopefully, I'll get to attend this year. Guard unit has moved drill to that weekend...
Crazy wind.
I metal blowing off of one shed roof. Im not fixing it in these gusts. I will end up in kansas..
