Stop in for a cup of coffee
Barristas like this can only make up for so much :rolleyes:
He cant even figure out how to press in bushings, you really think he can fabricate plates!??:poke::poke::thumbsup:
Actually I have no doubt Chris can fabricate most anything. He is a farmer....They can do anything with nothing..
It may not be pretty, but that I can do. Theres a CASE IH combine running around these parts with a fabbed drag link I welded up with a stick welder some 10 years ago and it hasn't broken since lol
Good luck. I did mine with various implements of destruction as below. I bought the full poly kit, but decided against them for the LCA pins. Had to have those pressed in at local garage since I did not have access to a press at the time.
https://www.forabodiesonly.com/mopar/threads/cinnamon-75-duster.220338/page-3#post-1970093355
https://www.forabodiesonly.com/mopar/threads/cinnamon-75-duster.220338/page-2#post-1970077949
I called my local shop and they were saying like $50 per bushing to press in and press out, plus parts!
In the end I just bought a $98 cheap Harbor Freight press and use some heavy pieces of scrap metal for spacing...
Wow its humid out! I just widened out the mulch rings around 4 little trees with a garden hoe (she was a big help, lol) and I am soaked in sweat. Now back out to do the mulching...
So, these 727s.... Would all th guts work in any other 727? At that price, just get a junker with a good case and swap?
Just need the car out shaft and tailshaft. Rest is the same or will interchange. Also, the RV ones have 4 pinion planetaries like the hemi cars did. Rest have 3 pinion planetaries.
Where did they park with the load of blocks? I wouldn't want to push that wheelbarrow load up your driveway...
They backed up the driveway to the end of the walk. Even just pushing it from there to the front door across the grass must have been hard enough since they had pulled the flagstone out before they moved the blocks.
I just wheelbarrowed a couple loads of fairly dense mulch up my yard which is a slight incline. That was enough after digging out the edges. I need to got o work and take break. LOL
T shirt weather here. Decided to put a window in my overhead door, good thing my buddy gave me 2.Broke the first one.more junk out of my shop and put to use. Think its time for a burger...
