Stop in for a cup of coffee
here it is
the notion behind this is to make it work with the 727 pushbutton. I'm not sure its possible but they make adapter kits to put one on a regular 727
You also need the body harness, wheel sensors, brake sensors etc. if you want to run that trans and use the stock PCM.
IH started building trucks in 1907. They built many medium and heavy trucks as well as Scouts (like a Jeep) Travelalls' (like a Suburban) and pick up's.
Mitch had one of these, a few years back. All original KB2 ,
216 flathead and all. Floor starter. Four Speed.
Dang, Tinseltown is taking a beating these days, more actors being accused of sexual crimes
"Sexual crimes" = how young unknown actress got into the movie business. They, the "victims" All knew what they were doing, might not have liked it, but they wanted to be in the movies, so they screwed there way to the top. NOW, after they are famous, "I was raped".
Can you put the sensors on an 8 3/4 rear of an old truck and make it work?
Yes, the sensors are in the fenders and on the wheel hubs. They just need to be adapted. You also need the TCM (Trans Control Module) and the main PCM to get it to work.
