LOL you are missing a FEW parts in there! Bell housing, crossmember.....................Nah t56s are aren't that bad
Yes I do . If I'd ever win the lottery, look out
Eh t56 1000 bucks, clutch 500. I'm not sure what a quality converter runs these days, but I bet it's close to that
Cross check the chart I posted. It will only raise the effective stall by around 100-150 RPM if you can shave off 50° F.I wonder If I install a trans cooler I will get better performance?
Yeah, way too hot for a 2500 stall when the engine is tuned properly with the exhaust you added. I'd pick a 3500-3800 converter to get the most out of it and add a tranny cooler to keep it in that range. I wouldn't go below 3400 nor above 3900. One could still get too tight and the other will be too loose until it's hot.I dont know if you saw the Camshaft im running..
A good plan.Yeah, way too hot for a 2500 stall when the engine is tuned properly with the exhaust you added. I'd pick a 3500-3800 converter to get the most out of it and add a tranny cooler to keep it in that range. I wouldn't go below 3400 nor above 3900. One could still get too tight and the other will be too loose until it's hot.
Seems right. Just make sure it has the correct balance (external vs. neutral).What about this?
https://www.summitracing.com/parts/hup-24-35/overview/
Right.Seems right. Just make sure it has the correct balance (external vs. neutral).
oy - that might be an issue - I am using it for strange
very nice BTW - - you're going to be happy with a nice big d_ck..
maybe the trans simply needs to be serviced
You just HAD to go there huh!!You are going to get on your knees for Bruce Jenner???![]()
What about this?
prob just standard pic.Aren't Mopar converters supposed to have the flywheel attached???
I don't see a flywheel on the one in the picture in the link... Are you sure that's a mopar converter or did they use a "standard" picture for the posting???
Hell im still up!First...
Hell im still up!
