Mostly the strut rod bushings are shot.I think I have tracked down the issue, a little of a few things. Just though while I had it apart for new brakes, I would look into this. Thanks![]()
When I did the front end on the GTS, I found out that the Urethane bushings are to big, could not get the nut started on the front. Ended up using some good Moog bushings. Just a heads up, TimMostly the strut rod bushings are shot.
Did you swap to disk brakes??When I did the front end on the GTS, I found out that the Urethane bushings are to big, could not get the nut started on the front. Ended up using some good Moog bushings. Just a heads up, Tim
So I need to grab strut rods too for when I swap the polara's brakesDid you swap to disk brakes??
On the later cars which are often donor cars for disk brakes (73+) have different strut rods. Some are coarse thread and some fine thread, they are slightly different enough to cause a problem like what you are talking about. Had the same problem when I swapped disk brakes from a 75 duster to a 69 dart.
Sure, I understand, I did go to 73+ disc, But I was using the original strut rod bars... Still no go , with the urethaneDid you swap to disk brakes??
Sounds like funNot a fun day. Vehicles caked in snow,so got a couple unwanted showers. Not my favorite days.
Pop in one headlamp and day is done. Nothing booked tomorrow, some more cleaning on the 318, maybe pull the heads....
Yep. There's a page on my website about measuring and cutting the poly ones to fit.Sure, I understand, I did go to 73+ disc, But I was using the original strut rod bars... Still no go , with the urethane
What website?Yep. There's a page on my website about measuring and cutting the poly ones to fit.
I'll stay quiet then.....IDK why, but today was one of those days were I was irritated and pissed of by everyone and everything. All day I felt like I was ready to bite someone. Zero tolerance for stupid.
I tell people to bite me everyday. Must be a phila. Thing.IDK why, but today was one of those days were I was irritated and pissed of by everyone and everything. All day I felt like I was ready to bite someone. Zero tolerance for stupid.
I forgot the name of the cheese we were talking about a few weeks back.Yeah, I can't point at any one thing that started it but I felt like a pressure cooker on slow boil that just kept getting hotter as the day went on.
Maybe my gyvashyter is broken.
...Was it cacio or caciocavallo?
Had those days. Then something goes awry and all hell breaks loose. I gave up on the explosions,got no time for stuff like that. I just find something i want to do,most often its go for a drive.phone off and i dont talk to anybody.Yeah, I can't point at any one thing that started it but I felt like a pressure cooker on slow boil that just kept getting hotter as the day went on.
