1st good morning!
Has to wait for a whille. Was hoping for more $$$ at Carlisle, weird year there. Saturday kind of sucked.Hey Ray! Hows things doing, hope all is well. Installed that Petronix you sent me, made a difference.Morning again!
Factory location at the back of the block but with an aftermarket mechanical gauge. Engine at full temp. 5W20 oil.Depends on where you're measuring it, but in general 45 at idle suggests very high viscosity (normal if the engine is cold). At idle the pump isn't moving that much volume. If the measurement is close to the pump, high pressure means that little volume isn't flowing up through the engine.
When the pressure is high because the oil is too thick its like this.
It's not getting more flow to the top no matter how much pressure is added.
How tight are your bearing tolerances Chris? Mine are on the low side so expected higher pressure and ower volume in it.Factory location at the back of the block but with an aftermarket mechanical gauge. Engine at full temp. 5W20 oil.
No clue. Never took it apart to find out.How tight are your bearing tolerances Chris? Mine are on the low side so expected higher pressure and ower volume in it.
Something aint right then.Factory location at the back of the block but with an aftermarket mechanical gauge. Engine at full temp. 5W20 oil.
