Subframe connectors needed or not?
hard to get them that nice doing it from underneath laying on your back
i would not do it with the dynamat and carpet installed. even the jute backing on just the carpet would make me hinky
You could weld in 2 x 3 .120 wall connectors held flush with the bottoms of the front and rear rails. This will leave a gap above them and not touch the floor pan.
This will allow room for the parking brake cable and fuel lines too.
You could weld in 2 x 3 .120 wall connectors held flush with the bottoms of the front and rear rails. This will leave a gap above them and not touch the floor pan. This will allow room for the parking brake cable and fuel lines too.
just what i did, and like you say, no parking brake cable issues
I'm going to install the bolt/weld in type, can't hurt. My current slant six can't twist anything, but I built the rest of the suspension (T-bars, sway bars, shocks, upper/lower control arms, borgeson box, steering arm bearing, 8.75 posi, rear leafs, 15" tires, front power disc brakes, etc.) for an eventual v8 upgrade, this was the only piece I didn't upgrade.
I do like the simplicity there, but I would much prefer to involve attaching them to the floor pans. It would make for a much stronger structure, IMO.
How much hp/torque can a 67 A-body take before really needing subframe connectors? I don't plan to hit the drag strip a lot, but I think it only takes one shot to bend it if it hooks hard enough.
If recommended... What aftermarket BOLT in type do you guys recommend? I know weld in ones are better, and I may do a bolt/weld in combo. I really don't want to pull the seats and carpet just yet.
**** a stock slant 6 car can and will benefit from frame connectors..
i followed this in the past and they worked out well. https://web.archive.org/web/20080216222924/http://www.bigblockdart.com/techpages/connectors.shtml
Weld In Your Own Frame Connectors
"Weld In Your Own Frame Connectors
Frame connectors are an excellent way to stiffen the body of your old unitized Mopar. However, dont think it's only for race cars...Theres a noticable difference in handling and steering on the street after adding them. These old bodies flex much more than you'd think. Some basic welding skills are all thats required, or you could get everything fit and ready, then drive the car to a welding shop where someone could weld them in for you in about an hour. You wont be dissappointed with the results.
The connectors shown above were home-made from 2x3x.125 mild steel and they slide right over the rear frame rails.
The plates on the forward end are 2x6x.125 mild steel plate. The length of these bars are 53", but it depends on how much you want to overlap the rear frame rails. Aftermarket weld-in connectors dont over lap at all, but just have an angle cut to butt directly against the leading edge of the rear rails. Thr bars pictured actually go right back to the spring eye boxes for the inboard leaf springs, and have a small slot cut in them at the end to clear the old spring hanger brackets.
Holding the bars up shows that with them lined up with the rear rails they're actually a bit to the outside of the front rails.
Mark the location and clean the weld areas well. Weldable primer or coating is also a good idea as it prevents corrosion in places that arent accessible after the part is installed.
When you fit the driver side, you'll notice the next hurdle. The parking brake cable runs through the frame right where you're connector needs to be. The original hole can be seen in the left picture. The right picture shows the front of the crossmember. Theres a second stamped hole above this. Simply drill through that hole and through the back side of the crossmember. You can also drill a whole new hole off to one side or the other. It's all where you prefer to put it. It just appears cleaner if you use the stamped hole thats there. You must also take care in removing the old grommet that holds the cable in place in the hole. Its bound to be close to the breaking point after 30 years. The photo below shows the new cable location directly above the connector.
A nice clean modification thats undetectable.
In these two photos, you can just make out the weld line where the connector overlaps the rails. On the left, it actually goes the full length and butts into the spring hanger bracket. The bottom continues right back to meet the lower edge of the spring box. Once you compare these pics to your own car, it will be evident how a few simple cuts will tie in this entire structure in the back.
Heres the full installation. Your car will now act like its 30 years younger. Also note the new exhaust that took place during these pics. The old Y-pipe can be seen in other pics."
Yes, after chasing out the old body work at the rear quarter seams for the third time in 13 yerars 1984-1997. “70 swinger 340” I said the next one I do WILL have frame connectors. It does and it is definitely is worth it. Bolt in or weld in either will help. No I would not attempt to weld in with carpet/interior in way to much chance for fire .Good luck…Swingn’
Frame connectors are an excellent way to stiffen the body of your old unitized Mopar. However, dont think it's only for race cars...Theres a noticable difference in handling and steering on the street after adding them. These old bodies flex much more than you'd think. Some basic welding skills are all thats required, or you could get everything fit and ready, then drive the car to a welding shop where someone could weld them in for you in about an hour. You wont be dissappointed with the results.View attachment 1715782985View attachment 1715782986The connectors shown above were home-made from 2x3x.125 mild steel and they slide right over the rear frame rails.
The plates on the forward end are 2x6x.125 mild steel plate. The length of these bars are 53", but it depends on how much you want to overlap the rear frame rails. Aftermarket weld-in connectors dont over lap at all, but just have an angle cut to butt directly against the leading edge of the rear rails. Thr bars pictured actually go right back to the spring eye boxes for the inboard leaf springs, and have a small slot cut in them at the end to clear the old spring hanger brackets.View attachment 1715782987View attachment 1715782988Holding the bars up shows that with them lined up with the rear rails they're actually a bit to the outside of the front rails.
Mark the location and clean the weld areas well. Weldable primer or coating is also a good idea as it prevents corrosion in places that arent accessible after the part is installed. View attachment 1715782989View attachment 1715782990View attachment 1715782991
View attachment 1715782992 .View attachment 1715782993View attachment 1715782994In these two photos, you can just make out the weld line where the connector overlaps the rails. On the left, it actually goes the full length and butts into the spring hanger bracket. The bottom continues right back to meet the lower edge of the spring box. Once you compare these pics to your own car, it will be evident how a few simple cuts will tie in this entire structure in the back.View attachment 1715782995
Wow, the E-brake cable move description is really helpful...thank you!
don't know if you noticed, the front and rear frame rails don't line up
i angled mine so they line up. didn't need to move the cable
@Jadaharabi , those look just like mine. $20 in scrap metal at the metal store.Cut and weld. I butted them up against the floor and tacked them where they were close enough. Nothing modded on the floorboard.
