Yesterday consisted of finish painting the engine compartment, finish wiring, removal of old transmission and drive shaft, also removed the heat shields, and test fit the motor .
As you can see the engine leans a little to the passenger side, so a little more grinding is needed to level out for the shaumaker mount kit. After grinding today, put the transmission to the motor and drop both in today !
