Sounds like a plan Mike, can't wait to the progress. And the tire smoke from the first burn out!
I sure will :glasses7:andLet me know when you have a for sale thread going:cheers:
It should be this weekooh! Can't wait to see some progress pics!
My son said I should put my 13" on and hammer it for a good /6 burn outSounds like a plan Mike, can't wait to the progress. And the tire smoke from the first burn out!
I'm inclined to agree! Before and after burnoutsMy son said I should put my 13" on and hammer it for a good /6 burn out before I take the engine and trans out Stan :burnout: sounds like a must do video to me :glasses7:
sweet! Getting closer!Thank you WRB426, I now have some Schumacher S6 to 340/360 motor mounts for 63-66 A bodies:cheers:
because Holley....Moved on it today again MoparDaddy :glasses7: It was a cool day on the hill ( 78 at noon) :cheers: That Carb (390 Holley) has never leaked or gave me any problem :glasses7: Wow the last time I seen the inside of my intake was well over 4 years ago, looks like a good cleaning and put it up on the chopping block for sale one day soon :glasses7: I removed the Radiator but did not down size the pictures from my phone yet :banghead: I still need a camera, sorry for the junk pictures
because Holley....
Thank you David, I am going to need more flow for my 360 .Ain't saying you gotta use them, but you could sell them for enough to make the difference between a set of Hooker fenderwells or a set of Doug's chassis exit...
i have read multiple times that the magnum truck manifolds fit the early a with a small block. i picked up a set just for that reason for $40 at local pick and pull. gonna see how they fit in my 65 valiant. even if you had to angle mill to get em to fit it would be well worth it. they are suppose to flow pretty dang good for manny's
Only thing I see getting in way would be steering outer housing. You stickin with column shift?
Well younggun I here ya and think I know what you are saying.Then you could trim back outer steering column sleeve and install a colar bearing
Are you talking about the steering coupler ? And do somthing to it ? Or are you talking about whete the steering comes out on the fire wall ? Sorry.. a picture would help i guess.
And the correct year/cast number of what manifolds off a 360 .
I must be getting tired .. I ain't going to say old![]()
:cheers: WOW! Thank you younggun. You sure fixed me up young man :color:
dutra duels?hopefully I will get the drive shaft and trans member backed off and pull the /6 this week :cheers: in the last pictures those are the 13'' wheels and tires that came with/stock on Victoria![]()
