Mad Dart
Nothing to see Here!
Been busy mapping out my wiring diagram. This is WAY more complicated than wiring up a Car Stereo with 6 Amplifiers and 24 Speakers I can tell you that! Been there done that more than a few times.
Anyway, I had to order up some more parts. Diyautotune.com sells a Relay panel that has 3 Relays with 4 fuses. I need one with 8 Relays and 12 Fuses to start so obviously I will be making my own. I ordered a 6 bank Fuse Block just for the EFI that will incorporate 2 Bosch Relays to control it and another Separate 10 Fuse Block for 6-10 more Bosch Relays total for the Accessory's like Radiator Fans, Meth Injection, Water Pump for Intercoolers, Heat Exchanger Fans, 3 Step Rev With Line Lock. There will be a couple more extra's for Future Upgrades like NOS Stage 1 & 2. A Trans Controller etc. What is cool about all this stuff is that the MS3 will control all Turn on & off times for everything I mentioned above.
