Weight comparo: HDK vs Stock
HemiDenny
HDK Suspension
NW Ohio
HDK vs. Stock K-frame weight comparison
All measurements taken with a new digital scale
stock K -frame assembly w/manual box and steering linkage ..................................60.8 lbs
stock A arms without lower ball joint/steering arm...............................................38.2 lbs
stock torsion bars and front shocks..................................................................19.4 lbs
stock total.................................................................................................118.4 lbs
HDK K-frame assembly w/manual rack (includes steering linkage)............................47.6 lbs
HDK control arms, upper shock mount, chromoly support hoop and hardware.............25.8 lbs
Alden Eagle coilovers/ #654 (pair) complete assemblies w/ 450 lb springs.................15.1 lbs
HDK total............................. ......................................................................88.5 lbs
..............................DIFFERENCE...29.9 LBS
*weights do not include the lower ball joint and spindles.
**for a fair comparison I weighed the stock and HDK lower control arms w/ sway bar mounts.
The HDK K-frame has sway bar mounts, but the stock assy did not.
Those K-frame pics are rather crappy quality (cell phone pics) so here's a
couple of close-ups to show the quality. All pieces are tabbed and slotted.
Good stuff. What do your K's run, cost wise?
Glad you asked..
I sell the fabricated pieces....
...the K with sway bar mounts and motor perches
...chromoly upper and lower control arms
...upper shock mount/ hardware
...support hoops/ hardware
$1900 (most applications) plus shipping
I supply a detailed list/ part # of components needed to complete the build.
List available to everyone.....see below
Nice looking parts Denny. What is the intented purpose of your parts? Do you have any graphs of camber gain, roll center height, or bumpsteer?
Great prices, If I ever go aftermarket, HDK is the top of the list. I like your style. :D
some 20 years ago, my intent was to get rid of the steering box to allow room for a Hemi in a A body.
The intent is still pretty much the same as when I started, Eliminate the bulky, worn out, 40-plus year old steering box with rear steer linkage and replace with a modern, compact, off the shelf, rack and pinion assembly. Also remove/replace the torsion bars to gain room for almost any exhaust you can imagine. And shed a few pounds along the way.
here is the tricky part, for me anyways.
no welding or cutting....100% bolt-on pieces
no exotic ($$$$) parts
use the existing upper control arm attaching points. This somewhat limits what you can do with roll center, however, it can be tuned/improved with extended upper ball joints. Further difficulty arises because of the simple fact hardly any two cars sit at the same ride height.
keep the front wheel / tire combo tucked into the front fenderwell for turning clearance and a better look
sorry..no graphs at this point. gotta put that one on top of the list. There are some pics on another thread showing camber gain thru-out travel.....it is virtually zero, however, due to the upper arm being shorter than the lower arm, there is naturally going to be some camber gain at full compression.
Wouldn't mind having one just for the gorgeous welds!!!
Glad you asked..
List available to everyone..just PM me
Wow thats a great price :prayer: Compared to some other aftermarket options. Guess I need to start saving now :D
they are some sweet looking welds....
whats the parts the purchaser has to buy usually come in at ? ball park price?
Not gonna take anything away from Bill,but, I gotta say Denny that this is alot more visually appealing even without the price savings. It has looks that to me instill more confidence.
I've checked out some other setups that looked decent but I
think this one looks like the most thoughtfully engineered and
constructed.
I also want to be able to run decent sized front tires and have
them tucked up into the front fenders.
When it comes time for me to "get busy", it will be a HemiDenny
K-Frame for me.
Thanks Dr H., I will look forward to it.
Here is the list of needed components you can buy direct from your favorite jobber
(Jegs, Summit, Speedway Motors, ect)
Quantity:
1 ) #555-60781 manual Mustang II rack and pinion......Jegs $129.99ea
2 ) #910-34341 rack and pinion bushings...............Speedway $8.99ea
4 ) #555-64210 1/2"id x 1/4" alum rod end spacers......Jegs $2.49ea
8 ) #910-08051 stainlees steel poly end...............Speedway $14.99ea
8 ) #910-01156 stainless steel 5/8 RH jam nut........Speedway $2.99ea
1 ) #910-34304 2" drop mustang II spindles.........Speedway $169.99pr
1 ) #3910-615074 nuts/washers/cotter for spindles..Speedway $6.99set
4 ) #40-3202 Moog 772 screw in ball joint............UB Machine $21.20ea
1 ) G-tech MII tie rod ends (1pair)..........Fat Man Fabrications $46.00pr
1 ) Alden Eagle coilovers .................................Alden Eagle $388.95pr
1 ) 11/16" x 2" bump stop(pair)..............................Jegs 8.99pr
1 ) 2 1/8" x 2" bump stop(pair).............................Jegs 8.99pr
Sub Total...........................$1016.88
Optional: additional rear crossbar where drag link would normally be
(Note: some oil pans will not allow)
1 ) #910-34258-20 5/8' steel swedge sleeve...........Speedway $12.99ea
1 ) #910-01156 RH stainless steel jam nut................Speedway $2.99ea
1 ) #910-01056 LH stainless steel jam nut................Speedway $2.99ea
Add..................$8.97
Other Options:
Addco sway bar made for the HDK (dropped shipped included)
7/8" , 1", or 1 1/8".....................................................add $150.00ea
Substitute:
Wilwood Pro spindle..............................................Wilwood $349.00pr
Power Thunderbird (re-built) rack and pinion...........Speedway $199.99ea
1" extended ball joints w/tool.......................................QA1 $100.00pr
virtually zero, however, due to the upper arm being shorter than the lower arm, there would normally be some small camber gain at full compression.
The art of suspension
With no bump steer, proper ackerman and almost 4" of travel,
watch the camber change (it doesn't):
Fully compressed - 0 degrees
Now at normal ride height - 0 degrees
.......and finally fully extended - 0 degrees
Denny, Great looking stuff! Have motor mounts for a Gen 3 hemi?
just finishing new perches that will allow the same K to be used for your favorite Mopar powertrain....small blocks to big blocks to new gen Hemi.. ALL the SAME K
just change out the Schumaker Creative Services spool mounts exclusively produced for the HDK.(est...$159/pr)
I have built several proto-type new gen Hemi mounts and the production piece should be finished in 30 days. The small block and big block mounts are done and just starting production.
