highwaystar
Excellent information. Thank you for being patient. I will certainly take this up very soon. Looks like I'll keep the heads and have them install new valves, seats, seals and work in dual valvesprings. Should I stay with stock intake/exhaust diameters? Probably won't port. I'm guessing rod length for 340's are 6.123? I'm guessing stock pushrods length would work with the cams some of you suggested? Probably keeping stock rocker arms unless they're worn out. I also forgot to mention that I have an edelbrock rpm manifold and 650 holley double barrel. I'll def be on a lookout for a quality engine builder when the time comes. I just want to be well informed about mopar engines. Been a sbc guy![]()
With that manifold and Carb and a decent converter, You are already there in my opinion. Whip up on the 350's and 302's all day. I have a stock bottom end,J head motor with a little bigger cam, running 12:50's, Now this was also geared for 1/4 mile. But for the street, You being a previous s.b.c owner, You will be suprised how little you will have to do to make power. Don't be scared to put R.P.M.'s to it. It Likes It..
