What Are You Doing To/With Your Car Today?
25 teeth - light green
26 teeth - red
27 teeth - beige
28 teeth - light blue
29 teeth - black
30 teeth - yellow
31 teeth - green
33 teeth - yellow
34 teeth - green
35 teeth - orange
36 teeth - red
39 teeth - green
40 teeth - orange
41 teeth - red
45 teeth - yellow
Thanks for posting up that chart Jeff !
Nice looking fish, and sounds great. I'm guessing from the sound of the idle, you put an aftermarket cam in there ? And the engine looks great with the 273 valve covers.
Thanks,
I sent the cam to Ken at Oregon Cam Grinding for his 1280 grind. It's .517/.215 at 110. I was hoping to keep the 273 Commando air cleaner but that dang Air Gap is too tall.
This is the build I always wanted to do but never wanted to spend the money on. Screw it, life is too short!!
Its 54° and dry in Avon Indiana today, so I moved the car out of the garage to get to the yard working stuff. That required a trip to Autozone for octane boost, which was really just an excuse to go for a drive. Which was another excuse to take pics and post them on here!
Took the heap out on its maiden voyage. Ran and drove pretty good . Still needs a few minor adjustments .
Took advantage of the 60 degree, Rhode Island weather today!
Hoping to finish up the rot repair in the engine compartment this weekend so I can do final prep for paint......just firewall forward for now.
Also picked up a 4 speed for the standard conversion.
Weld in new inner fender braces.
Make sure they fit and get a good door gap.
Clean up the insides . .
like new, 50 year old fenders.
What did I do today.
Failed at math
I tried to measure the length of driveshaft I need in a car that was missing the original driveshaft.
Convinced I had the math right, i acquired a used driveshaft from a salvage yard, brought it home and changed the u joints to brand new joints since the used ones have been outside for probably 20 or 30, maybe even 40 years.
Went to put it in the car thinking I was home free.
Overshot it by about 2 inches.
So I guess I need to go back and find one 2 inches shorter and repeat.
That will be nice if you can find the right length drive shaft now next time, no cutting, welding and balancing with original mopar.
Keep going and scare up the next one, and now you have one to sell to someone else for whatever purpose.
Helped my brother get his sons car ready for the exhaust shop. Power train installed, and mostly wired up. Goes for exhaust in the morning, then we get it running to break in the freshly rebuild AMC 360!
