Ground to rear k bolt: 11"
Spindle centerline to the ground: 13" with a 2" mustang drop spindle.
26" overall tire diameter 20" wheel
Hub face of rotor to frame rail: 12" I might feel better if we could move that in a hair for turning at speed.
my silver Duster is at 12" hub to frame....Ross's is a smidge closer (as far as I can remember)...maybe 1/8" .....there is adjustment to move it closer in the threaded poly ends, the limiting factor is the coil spring (coil over) clearance with the factory frame bumpstop for the lower control arm. The frame bumpstop, of course, can be removed
shock mounts..included.
shock hoops slightly x-tra
I'll e-mail you a total
