Pete in NH
Good Morning,
Please take Redfish's advice very seriously, people have lost cars due to this kind of issue.
I believe you said that you put your test light between the negative battery terminal and the negative battery cable and it did not light. Is that correct?
Also, please look at the back of the alternator very carefully. There are two styles of round back alternators. One is the 1969 and earlier which has only one field terminal connection. The second type is the 1970-1971 style that has two field terminal connections. After looking at the back of the alternator closely, Which one do you have?
Disconnect the blue wire from the regulator and with the battery connected and ignition key in the run position do you have 12 volts from the blue wire to ground?
Please report back on these questions and please do not leave this car with the battery cables connected unattended for even a second.
