DesertRat
Leading edge boomer
The build: 1967 273, Stock heads, 10.5 Egge pistons .040 over, Lunati matched cam, hydraulic lifters & springs, LD4B intake with Holley 4160. Duration @ .050-IN 213 EX 220 lift IN .454 EX .475, LSA 112. About 2 hours total run time, 150# compression on last check.
The tune: Stock distributor with Pertronix conversion, coil & wires, distributor recurved to 34 total from 12 initial all in at 2500. Hot in gear, idle at 700 rpm with 8" of vacuum. In neutral idle goes to 1000 rpm, forgot to check vacuum.
I have not checked jets size but the factory AFB wanted .089 mains and .073 secondary's.
Just wondering about the vacuum, seems a little low and I will be changing power valve based on hot idle vacuum.
Insight welcome as always-------------Cheers---------DR
