GMachineDartGT
Senior Member
Thanks Clair!I never get tired of seeing this car!
Rears in 3/4 lips trimmed.what mods to get them to fit? aren't your rear springs moved in 3/4"? any mods to get the fronts on?
Front lips removed entirely. The big brakes in the front change the offset slightly, but the 18" allows me to use a 6.4" backspace. It fits perfectly. I can run tight clearance because the body doesn't roll too much, tires are stiff and the offsets are just right.
assuming you have a mini tub? or Is this the factory rear suspension?1971 Demon
18X10.5 rear 275/35-18 Michelin pilot supersports
18X9.5 front 245/40-18 Michelin pilot supersports
Couple little tweaks with other additions and she will be back on her feet and I will add a few more.
What back spacing/ off set on front and rear?Well I posted here before with my old 14" Magnum 500 set, but now I changed them out for a set of Weld Prostar's(15 rear/14 front) with 245/60/15's in the back and 195/60/14 up front. But now that they are ont he car I'm going to go for a little taller tire up front and then lower it a little to get the stance right. The rears are pretty snug in there too. But I'm very happy with the switch.
If memory serve they are 15x8 or 15x7 with a 4.5" backspace in the rear. id have to measure the front when I get back home but they are 14x6's and I cant remember the backspace on those. I have much better pictures of the care since that post.What back spacing/ off set on front and rear?
Post a side pic and rear of your car please. Looks awesome.Currently I have 255/40-18 in the front on mine with 8mm spacers, there is easily room for the 275/35-18 on mine. The lip is rolled on the front and I modified the leading edge of the front fender. The '67-'69 Barracuda fender has a different shape than the Dart. I made a photo garage on the fender mod: 1968 Barracuda Front Fender Modification for 26" Tires
On the rear I currently have 295/40-18. It will easily fit a 325/30-19 and might even clear a 345; I previously had 325/50-15 Drag Radials under the rear with plenty of clearance. Car has mini-tubs and relocated springs. The fender lips are rolled in the rear also.
Here is a link to pictures of the car undergoing chassis mods and paint: 1968 Barracuda Notchback: Paint and Body 2014
That is bad *** man. I LOVE seeing cars like ours fixed up right. I get a lot of crap about mine being a 74 but every time I see a car done right like yours it gives me hope. I'll be ordering wheels for mine here very soon and was trying to find a reference of what size to order.If memory serve they are 15x8 or 15x7 with a 4.5" backspace in the rear. id have to measure the front when I get back home but they are 14x6's and I cant remember the backspace on those. I have much better pictures of the care since that post.
This one is before I switched the front tires.
This is my current setup with the bigger front tires.
I probably shouldn't have jumped the gun but I ordered these today. 338 for all for from SummitIf memory serve they are 15x8 or 15x7 with a 4.5" backspace in the rear. id have to measure the front when I get back home but they are 14x6's and I cant remember the backspace on those. I have much better pictures of the care since that post.
That barracuda is sexy af...
Looking sweet jpar, I was thinking about the black 5-spokes off the cop carsNot a big fan of the big wheels, but $200 for rims and tires ? OK?!
OF A "05" MAGNUM (street first picture - strip second)View attachment 1714827287
Like your setup.....the wheels and tires look good. Wanting that size of Cobra's for my Duster.This is my 73 Duster with a comparison between 14" and 15" wheels. The top pic is 225-60-14 front and 235-60-14 rear, the bottom is my new setup, 215-65-15 front and 255-60-15 rear. The front wheels are 14X7 and the bottom setup is 15X7 front and 15X8 rear.
Thanks for the compliment! I think I stumbled on a winning combo.That ride height is perfect and those wheels fit the car well. 17's are the perfect compromise.
@leechris81 tasteful job
Really just door panels for a 65 dart 4 doorWhat exactly are you looking for ?
You can post on the parts wanted section on this site, and also check the parts for sale section.
Welcome to the site.![]()
And thanks for the welcomeReally just door panels for a 65 dart 4 door
