RAMM
here it is, the comp hydraulic roller / cast core i mentioned. That´s the reason why i still believe that the one in the van is the same cast core...and compatible to the stock oil pump drive.
Michael
That cam will work just fine with a stock gear as it is undoubtedly CAST. J.Rob
Sometimes when I'm broke I'll mix in some atf.
