Shaun65dart
Hey guys. Frustrated because I’m having trouble figuring this out. 65 dart gt slant 225. All stock besides Petronix ignition. My bearing went bad in my square back alternator. I have two wires in addition to the battery wire. The two wires are green and other is white. On the replacement alternator, looks like there is one terminal for a field wire, and the battery post. When I hook up the alternator with the green field and battery post wire, it’s not charging. The other field wire is just hanging there. I read if you ground the other field to the casing, that should do the trick but it does not. How can I wire this alternator to work correctly? Here’s a picture of the back of my new alternator and the one I took out
