Post your wheel and tire combos.
Cops used to pull you over for wide tires, I think it’s in the past anymore. Maybe 1” at the most past the quarter panel, they’ll be more worried bout the 440 with 3” exhaust
I just saw Zoomies on a '32 Coupe the other day 2 blocks from the Police station in the middle of town :lol:
Has anyone installed a rear disc brake kit for a 8 3/4 differential,what Brand?, also does this change the BS on the rear wheels?
I have rear disc brakes from Wilwood with my 8 3/4 sure grip rear. I don't know what the BS was before or after since I bought the car with them. I run 18" wheels which give plenty of clearance to the inside but it's tight up against the fenders. I run 235/40-18 tires.
So, bad product? How bout Baer brakes, or any recommendations out there? Rear brake kit, or full car disc brake kits?
Many of the conversion retailers are using MBM brake kits that are repackaged with "Company XYZ" but are drop-shipped from MBM in Asheville, NC (HOME (mbmbrakes.com)) Products of China, but unless your pulling OEM and reconditioning/modifying there are not a lot of options available. As stated earlier, do your research and understand what your needs are.
Good luck
Hi everyone! New to this looking for some help. I have a 65 barracuda work in progress. Wanting to put new wheels and tires on. Have found some but not sure they would fit. Any help would be appreciated. Thank you. Will these fit?
Front 215/60 14
Rear 245/60 14
Front 215/60 14
Rear 245/60 14
I have a 1968 Dart, but those should fit no problem
Front 215/60 14
Rear 245/60 14
They should fit, but only if the wheels have the correct backspace.
Cragar D-Window 15x7
Front: 205/60/15
Rear: 225/70/18
img_20220122_155450_143-jpg.1715858351
img_20220122_155450_111-jpg.1715858352
I threw these on my dart because I was cheap and I love the look now.
