abdywgn
dismantler
basically this is a "blueprinted" 318?
It would appear that you dont understand how offset grinding a crank worksJust because he said something about offset grinding the crank, doesn't mean the stroke will be any different. Just that they want to move the piston higher in the bore at TDC closer to zero deck.
If they are using original 318 rods they can't move it much, a 30 thou regrind usually means 15 thou off of stock "all the way around" I guess they could take most of the 30 off the underside of the crank throw, and little off the "top side" which wouldn't alter the stroke from oem.
I sure do.i guess that would extend the stoke by the amount of offset.It would appear that you dont understand how offset grinding a crank works
They already said that is exactly what they plan to do. So, we will get to see that difference.What would be fun is when they are done, regardless of the HP it makes, install a 4bbl and see what it makes for HP to see how much that 2bbl hurts a well-prepped 318. Maybe I'll suggest that to Andy
As much as i like what they are doing, I will say that I don't know how budget friendly this would be for the common man. All 3 of those guys would tell you that 318 hp would come much cheaper if you could just buy performance parts. I think turning a crank to stroke, porting heads and bench flowing, and such as that would be high dollar prices if a common man had to pay it at a machine/performance shop.They already said that is exactly what they plan to do. So, we will get to see that difference.
Personally, I think this is the most interesting build going on at the moment that I've heard of. Seems it is mainly all about the small details and not the big dollar parts most throw at a build. It will be really interesting to see what they all do and what the final result will be.
There's no way you will even get close to a 3.58" stroke by offset grinding a 318 crank.Interesting video. I was really looking forward to this series, mainly to see what kind of ways he'd show to free up parasitic HP losses. If they end up stroking the crankshaft by offset grinding (as he mentioned they "might") then I've lost all interest. At that point it's no longer a 318, more like a 318 with a 360 stroke.
If he offset grinds it to small journal SBC size, he could gain about 0.13 which would put the stroke about half way between a 318 and a 360. Hopefully he's just adding a little to get the pistons to the top of the bore as others have suggested.There's no way you will even get close to a 3.58" stroke by offset grinding a 318 crank.
this, 100% this.As much as i like what they are doing, I will say that I don't know how budget friendly this would be for the common man. All 3 of those guys would tell you that 318 hp would come much cheaper if you could just buy performance parts. I think turning a crank to stroke, porting heads and bench flowing, and such as that would be high dollar prices if a common man had to pay it at a machine/performance shop.
once you start machine work and porting, you're just putting a monocle and top hat on a chicken and calling it a duck.
^like^Tony said in his latest video something to the effect of "there has been a misunderstanding this isn't a low cost budget build" that in my opinion negates or even alienates a 318 builder. If one is going toAs much as i like what they are doing, I will say that I don't know how budget friendly this would be for the common man. All 3 of those guys would tell you that 318 hp would come much cheaper if you could just buy performance parts. I think turning a crank to stroke, porting heads and bench flowing, and such as that would be high dollar prices if a common man had to pay it at a machine/performance shop.
Exactly about it not being cheap. Wrong on the second part of your statement as I love the 318 but also love using your brain to get the most out of what you have. I think most of you are missing the whole point of the build which is all the little details that add up.Tony said in his latest video something to the effect of "there has been a misunderstanding this isn't a low cost budget build" that in my opinion negates or even alienates a 318 builder.
yes, i agree. i was answering your post about it not being budget friendly after you said "not big dollar parts". These parts they will be using will be "bigger dollar parts" than if you bought aftermarket performance parts was my point.Like someone else has mentioned above, they never claimed it was going to be a budget build. Having someone do what they plan to do to any size or brand of engine won't be cheap. I think the idea is to show how to maximize what you are working with which in this case is a BBD fed 318.
This build is certainly not the cheapest way to try to achieve 318 hp from a 318 for the normal guy. This is a "see if we can" build.Pick the low hanging fruit first. They will spend more for less performance. That’s idiotic where I come from.
Unless you like to fluff your ego.
To this remark ^^ I will say that I don't think most missed the point as much as maybe, by accident, were a little mislead. When it was announced by UTG, it was "see what we can do with a stock 318 using stock parts". The goal was 300 hp at that point. I think most believed the point was to take a 230 hp and tune/tweak/recurve/jet/ to get the 300. It wasn't very plain that they were going to grind, regrind, machine, piston swap, etc. Again, still a cool build. I think that is where the confusing was for most people.I think most of you are missing the whole point of the build which is all the little details that add up.
Mmm, I think that was their assumption and they mislead themselves.To this remark ^^ I will say that I don't think most missed the point as much as maybe, by accident, were a little mislead. When it was announced by UTG, it was "see what we can do with a stock 318 using stock parts". The goal was 300 hp at that point. I think most believed the point was to take a 230 hp and tune/tweak/recurve/jet/ to get the 300. It wasn't very plain that they were going to grind, regrind, machine, piston swap, etc. Again, still a cool build. I think that is where the confusing was for most people.
