I’ve not had the chance to run my Barracuda for long, but I’m seeing oil build up on the manifold in front of the carburettor, looking in the filter I’m not seeing any signs off oil so at this stage I am thinking dipstick or from the valves on the valve covers.
The previous owner had removed the breather from one cover and instead there are 2 PCV valves neither of which is connected to the vacuum port on the carb, so I’m guessing not a lot of cross ventilation is going on and potentially any build up of vapour etc isn’t able to escape through them.
Even if this isn’t contributing to the leakage I’m thinking I should try to set up a functioning ventilation system. Would anyone have any thoughts on PCV valves to use? The air cleaner housing has a pressed blank for drilling out to insert a fitting to run to the breather, or I could use a breather with a built in filter but I have read they can be problematic if not baffled.
Sorry should addd: 318 with a Holley 4BBL and Street dominator manifold.
