I'd try to find a pair of the old Mopar Performance steel shim head gaskets. They go down to like .018" - .020".
Yeah while its all apart get some thin head gaskets on there for that compression bump.I'd try to find a pair of the old Mopar Performance steel shim head gaskets. They go down to like .018" - .020".
I don’t remember. I read about it a while back which was an interesting read that I am so sorry, can not repeat because I didn’t retain it.
But I do remember the depths were like a sneeze of nothing deep. It actually seemed laughable. But it works.
Considering you can have a cam cut really heavy and have it heat treated again and perform great, I see no big deal in regrinding cams and cranks and then re heat treated again them.
So researching this a bit, the short answer is, they use a diamond tipped tool pressed in to the surface at varying pressures and create a curve of the hardness compared to depth of the indentation left by the tool. Another method is to cut a cross section, an oblique taper, or a stepped cut of the part and observe. Different testing for different methods of hardening, case, surface, etc. The end result is there is no way to tell the depth of the heat treat on a cam without destroying it in the process. Seems to me a company that regrinds cams should be heat treating them after the fact.I think it’s probably mostly gone, at least off the base circle. That said, I think the concern is laughable with
1. roller lifters
2. low spring pressure
3. low rpm
4. not very aggressive profile
5. casual use application
The reality is that you never here about regrind roller failures that have anything to do with the cam itself.
In fairness to the company, they totally have a right to not want to take on that risk.
Someone should drive a fairly deep regrind 300,000 miles to see if it really makes a difference. Me?
I'll report back in thirty years.
i'll take care of that for ya...Someone should drive a fairly deep regrind 300,000 miles to see if it really makes a difference. Me?
I know bullet told me that 20 years ago about my LA roller.....maybe they had different experiences with magnum rollers....i thought that ken up at oregon had said that most of the mopar cams were hardened fairly deep, like nearly thru & thru.
or at least that was my recollection? i don't know, don't quote me on it... i may have slept since then...
I called Oregon cams earlier this year to inquire about a regrind for my roller LA 408. Ken (I believe his name was?) advised against it because I told him I was looking for something pretty mild - around 230/236 @ .050 and .345" lobe lift and that was outside of what he'd recommend for a regrind. He said that would eliminate the surface hardening from the stock cam, even though the majority of the grinding would be on the base circle side of the lobe. He told me that the hardening on stock roller cams is pretty shallow and recommends VERY conservative spring pressures when they are used because of it.i thought that ken up at oregon had said that most of the mopar cams were hardened fairly deep, like nearly thru & thru.
He did. Says they are hardened slam to the core center.i thought that ken up at oregon had said that most of the mopar cams were hardened fairly deep, like nearly thru & thru.
The roller cores are different somehow. I have a BIG Cleveland solid roller I'd like to regrind to something much smaller, but Ken said it could be done, but it'd have to be rehardened and that would be cost prohibitive compared to another cam.I called Oregon cams earlier this year to inquire about a regrind for my roller LA 408. Ken (I believe his name was?) advised against it because I told him I was looking for something pretty mild - around 230/236 @ .050 and .345" lobe lift and that was outside of what he'd recommend for a regrind. He said that would eliminate the surface hardening from the stock cam, even though the majority of the grinding would be on the base circle side of the lobe. He told me that the hardening on stock roller cams is pretty shallow and recommends VERY conservative spring pressures when they are used because of it.
Use the clevite MS1266pHey, ordering some bearings off Rock Auto.
Which crank bearings would you get?
What was the clearance with the old bearings you took out?Hey, ordering some bearings off Rock Auto.
Cool. Would you recommend the clevite P series (CB481P8) for the connecting rod bearings as well? Thanks.Use the clevite MS1266p
Yes I would. The clevite p series is an excellent bearing.Cool. Would you recommend the clevite P series (CB481P8) for the connecting rod bearings as well? Thanks.
Haven't checked the old bearings yet, I won't place the order for new bearings until I do.
Whatever's on sale.Hey, ordering some bearings off Rock Auto.
If someone else hasn't mentioned it ...Ok folks, I am about done with the engine tear down.
My plan is to send the block and heads to the machine shop. Tell me if I have this right:
Block:
Heads:
- Hot tank
- Clean up head surface
- Light hone on bores
- Replace cam bearings. What cam bearings should I get?
Random:
- Hot tank
- Magnaflux for cracks
- If no cracks:
- A. Just a light pass to clean up/flatten the deck
- B. Mill some meat off the heads to raise CR?
- Valve job
- Should I have them install new springs? Or should I just do that at home?
- What main bearings should I order?
- What rod bearings should I order?
- I've done an engine build before (a 440) and did the rings, main, and rod bearings at home, but should I just have the machine shop do it?
- Anything else I should remember or consider before the machine shop trip? Like, should I bring him freeze plugs, galley plugs, etc?
Oh interesting... so should I do that before or after I get the cam back from the regrind? I was hoping to bring the block to the machine shop and send the cam out at the same time!If someone else hasn't mentioned it ...
Bring your cam with you to the shop. Tell them to make sure it spins freely after the cam bearing installation. Make sure you check this BEFORE you start putting the short block together.
Just have the machine shop check it with any cam. If yours is straight and the journals aren’t torn up it’ll be fine. You just want to check it before final cleaning because if it needs to be reamed, the block will need cleaning again.Oh interesting... so should I do that before or after I get the cam back from the regrind? I was hoping to bring the block to the machine shop and send the cam out at the same time!
Just have the machine shop check it with any cam. If yours is straight and the journals aren’t torn up it’ll be fine. You just want to check it before final cleaning because if it needs to bereamedshanked with the bearing knife, the block will need cleaning again.
