TT5.9mag
Two atmospheres are better than one
Just have the machine shop check it with any cam. If yours is straight and the journals aren’t torn up it’ll be fine. You just want to check it before final cleaning because if it needs to be reamed, the block will need cleaning again.Oh interesting... so should I do that before or after I get the cam back from the regrind? I was hoping to bring the block to the machine shop and send the cam out at the same time!
