440 Cooling Question “Champion Rad”
I'm looking at this Cold Case radiator to cool my 414 W2 engine.
This has been touched on a zillion times but here’s another thread with the same question.
My 71 Scamp build (link below) is nearing the start up phase. Standing in the way is the rad. I’m ready to purchase and I looking to save a few bucks and have decided to go with Champion. I went to order the rad and the tech told me to go with a 26” and dual 12” fans. He told me I’d have to modify the car to get this in. I’m not opposed to doing that. This car came originally with a 198 according to the tag. It currently has a 225 in her. So I’m going to guess it has a small opening where the rad sits. I have no access to the car until May so going to measure it is a no go. Especially with the mountain of snow we got. Has anyone done this operations? Is this something that can be done fairly easily? Does anyone have a part number for me to look at? The engine is currently on the run stand waiting on a few small items and the rad order. I’d like to run the stand with the rad that’s going in the car. This car will definitely be over the 550hp mark. She’s a full solid roller with all the goodies money tried to buy. Lol For details check out the link.
It’s been a long and winding road but there’s the light at the end of the proverbial tunnel.
Merry Christmas
Slow build 71 Scamp 440
On my '68 Barracuda, which was originally a Slant 6 car, I cut both sides out of the opening and had the bottom hose outlet moved over to fit a US Radiator I had been using effectively with a 440 in my E-Body to get it to work with the 5.9 Magnum I'm running. The fans are the max CFM Dual Spal 12" fans with their shroud and controller.
The black pieces in the picture are from the lower grill opening that I cut to better fit a pair of transmission plate coolers.
I'm running the MP viscous fan and a reproduction fan shroud. I'm hoping that I can make the shroud work with the ColdCase radiator.
I'll be curious to see how much clearance you end up with between the fan clutch and radiator. I wanted to run one of those Cold Case radiator in my '68, but there wasn't enough room. I ended up going with a Champion unit and still only have about 5/16" between the fan clutch and radiator core.
I know of which you speak. I had a 3 core Champion in a 67 and was struggling to make their crappy fans work. There was definitely not enough room to run the factory fan. If I am tight for space, Hayden makes a low profile clutch that should help.
I haven't even pulled the old engine yet, so it will be a while before I get to installing the cooling system.
That's the fan clutch I've got. It's actually one of their prototypes from when they developed that shorter HD clutch. It's still really tight. It doesn't help that the companies making these aftermarket aluminum radiators don't weld the brackets such that the radiator core is flush with the core support. They're losing some valuable space right there. Keep us posted!
That's the reason I'm using the Spal fans. There's no room for the superior factory fans.
When I was struggling with the Champion fans referenced above, I was ready to pull their whole shroud/fans out and replace it with one good Spal fan. They are a bit pricey but they move a TON of air.
Look at that space. wow that's close
Ok this was an exhaustive experience. Let me tell you about it. Leave now if you don't like stories.
Tons of phone calls and talking to techs and sales reps today. So I'll document today.
When I woke up the first call went to Champion Cooling Solutions. After being on the phone for about 30 minutes we decided the tube size in their 2 core rads would not make the cut and I wasn't ready to buy a 3 core. .75" pipes wouldn't cut it.. Was a no go. They said a stock 440 no worries. It's too bad there Rep was fantastic and wasn't going to sell me something that wouldn't work. So I moved on. Called Champion next........ and moved on. Called Cold Case afterwards and they were very helpful with tech and making sure I had and would have adequate cooling for my HP estimates. They then referred me to Summit for the order as they have better option into Canada. I talked to the Summit sales rep on my cooling needs and he confirmed with me that the rad I had picked out would do the job with a 16" fan that's doing just shy of 2900CFM. He also said the tubes were much much bigger. Providing I don't have an over happy water pump and the coolant can dwell a bit it will be solid. Then he hit me with the backorder. March 3rd ship date. I then said hold the phone and called back Cold Case. They said they had a batch of rads heading to Summit but also suggested I call Jegs, so I did. Talked to their tech / sales rep and came up with the same thing Cold Case, Summit said. I should be good to go. This rad is a bit shorter on top and 1/4 inch wider on each side. sSo it's going to fit come hell or high water. but will it cool. I will decently wake up this thread when I fire it up and will eat humble pie if need be. That being said I decided to order from Summit to my door.
**What the reps said. 180 thermostat pared with a 100amp+ Alt. My run stand 60amp will run the fan but not fully full out.
Told me to keep an eye on the temp but said it would probably not be an issue on the stand.
So now we wait. Summit said as soon as they showed it'll ship. I'm hoping it comes way sooner than March as I need some time to iron bugs found on the stand and also to see if this will cool the beast. If not I have an expensive rad for my stand and my next build. So won't be a total loss. uggg
I learned not only on this forum but also from friends that there is a varying opinions and options out there. Some of you are very passionate on the subject and I appreciate you all.
I can't wait for my 727 build up next. This is sure to be a thrilling topic. I'm definitely going with a bolt in sprag but that's another thread.
Thanks everyone.
Parts ordered:
Cold Case Radiators MOP753AK Cold Case Performance Aluminum Radiator Modules | Summit Racing
Cold Case Radiators EF-1 Cold Case Electric Fan Wiring Kits | Summit Racing
I talked at length with the Champion Cooling solutions rep about Spal. They have CFM down low and up high. We discussed the Spal 30102113 that was 257 each and moved 2467 cfm. That's was my choice if I went with Champion CS. With the 16" fan from Cold Case pushing 2800 plus change. so I feel confident in that department. Of course there is higher CFM fans from Spal and I may have to look into that if this 16" fails the test. It was funny but all the reps said single fan over duals. interesting
I'm looking forward to see where my engine lands on that big block K-Frame. Thankfully some time back @Jim Lusk confirmed I had a big block K-frame. Hard to tell if it was an original DC piece. I'm guessing my spacing will look much like yours.
Thanks everyone.
Parts ordered:
Ok, you don’t want the coolant “dwelling” in the engine.
Unless it’s 1945 and it’s a flat head ford.
Use a high flow water pump and thermostat (Stewart Components is all I use any more) and make sure the water pump is turning crank speed or faster.
Never under drive the water pump unless you are turning 8500 rpm and you need to slow it down to keep the belt on.
Thanks everyone.
Parts ordered:
Take that shroud off. It’s not a shroud.
It’s a flat air dam.
If you think I’m wrong go look at every Chrysler, Ford and GM shroud out there.
Not one of them looks like that piece of garbage.
It’s a shame they sell trash like that. They have to know better.
Sorry but this info proves that the tech support has no knowledge of thermodynamics
We tried to tell him not to go with somebody's package deal. Just like all the rest, he didn't listen. I hope it works.
interesting. I was told you wanted the coolant to dwell a bit longer in the radiator and to slow it down a hair and use a 180 stat. She’s a 6500 RPM. Not that she’ll see that. Mostly a cruise night special.
