Post your wheel and tire combos.
there small bolt,prob modified by stockton or someone,but very nice.Tires are 255/70/15,fornts will be 215/70/14,on stock 14 inch ralleys.
1973 duster
Front wheels- Cragar SS
Size- 14x6
Backspacing- 3.5
Tire size- 215-75-14
Suspension-stock
Rear wheels- Cragar SS
Size-15x10
Backspacing- 5.5
Tire size- 325-50-15
Suspension- SS springs moved in 1". Rancho adjustable shocks, Rear axle moved back 1" to center wheel, pinion snubber.
Pictures available when files are resized. Stay tuned.
Thougt long and hard about what sizr tires I wanted. decided to go with 215/70/14's. Stock ralley wheels ( I think 5.5" or 6" ). Wanted 205's on the front but Sears said BF Goodrich isn't making them anymore. Very pleased with what I ended up with. Hope these pics can help someone when choosing their own. No issues with rubbing.
Car year and model
68 barracuda FB
Front
225/60/15 BFG TAs (will swap down to 215/60s just personal preference)
Wheel Brand
Forged Cragar SS (by Weld)
Size
15 x 7
Backspacing
3.5 inch
Rear
275/60/15 BFG TAs
Wheel Brand
Forged Cragar SS
Size
15 x 8
Backspacing
3.5 inch
NB. Using shorter differential/axle housing than stock - inner wheels/tires just nicely clear leaf springs
I just put these on a couple weeks ago. I'm not sold on the rims yet, but they're kinda growin on me. Big improvement in handling over the skinnies i had up front even though the current tires are mismatched and of low quality. I have some .75" spacers coming for the rear.
1964 Dart 170
Front
Wheel Brand - no-name aluminum slots 4" bolt pattern
Size - 14x6
Backspacing - 4"
tire size - 215/70/14
Suspension mods - none, v-8 on /6 torsion bars so it rides low
Rear
Wheel Brand - no-name slots again, 4" bolt pattern
Size - 14x8
Backspacing - 4"
tire size - 245/60/14
Suspension mod - skyjacker air shocks pumped all the way up, stock '70 A-body 8 3/4 rear axle
I had to roll the rear wheel arch lips with some pipe to get clearance. the rims could definitely use another inch of backspace and everything would be fine.
-Tim
1975 Plymouth Valiant
Front
Wheel Brand: - Majestic 787
Size - 15X6
Offset: +6 mm
tire: - P205/60R 15 Cooper GT
Rear
Offset: 0 mm
tire: - P225/60R 15 Cooper GT
I went with 225's in rear as tire store didn't have 205's to match 235 Radial TA's he had. So I went with the Coopers and kept all 4 tires the same.\
235's would fit without any problems. I tried posting picture but it didn't work. Ill post one when I get home to my computer.
Front
Wheel Brand CRAGER
Size 14X6
Backspacing ? standard dish
tire size 225/70/14, alittle too tall
Suspension mods GAS SHOCKS, SSBC disc brake conversion & .890 TORSION BARS
Rear
Wheel Brand CRAGER
Size 14X6
tire size 225/70/14
Suspension mod GAS SHOCKS, REAR SWAY BAR, HD SPRINGS
Firestone Indy 500 tires with redline by Diamond Back Classics
Front
stock 14" x 5 1/5 rally
215 70R 14
90:10 competition engineering drag shock
Rear
Stockton Wheel 15" x 8" rally
5 1/2 back set
inboard springs
30:70 competition engineering drag shock
Pinion snubber
27" X 10" M/T Street ET
Front
Wheel Brand Center line auto drag
Size 15x5
Backspacing 2 1/2
tire size 205/60/15 (BFG)
Suspension mods none
Rear
Wheel Brand Center Line auto drag
Size 15x10
Backspacing 4 3/4
tire size 255/60/15 (ET streets)
Suspension mod 2 left SS springs
There on my 19Dodge Dart 3.9 efi witht the A500 overdrive and 3;55 posi
195X7X14 in the frt and 205X7X14 in the rear and that old 500 can lite the tires up.
71 scamp 245/60/16 rear (very minor grinding involved) 215/60/16 front on steel ford rims had to use adaptors and one spacer. on my 63 dart 225/60/16 rear 225/50/16 front on steel 98 intrepid rims had to use adaptorss no spacers super cheap and they look good! also the darts rear could swallow a 235/60/16 easily.
I am running a set of wheels from custom wheel market out of CA. The fronts are 15 x7 with 4.00 backspace and 215/60R15 bfg on the front and 15x7 4.00 backspace with 245/60R15 on the rear. Both are 4.5 bolt pattern. I am running a A-body 8 3/4 rear sitting in the stock location. The picture is of my unfinished car with the tires and wheels installed.
That's close to what my Valiant came with. I've since gone +4 on the wheels, and at least 3x more rubber on the ground. That Dart's gonna be sweet when you get her all cleaned up!
Clair
Car year and model 1966 Dart GT 1972 Demon
Front
Wheel Brand Mopar Stock Mopar Police
Size 14 x 4.5 15 x 7
Backspacing 4 inches 4¼ inches
tire size 195-14 235/60-15
Suspension mods Polyurthane bushings Poly, 75 K-frame
Monroe gas shocks
Police steering box
Rear
Wheel Brand same-o same-o
Size
Backspacing
tire size
Suspension mod none gas shocks
lateral Watts link
Notes: Closest radial equiv tire No rubs
Have sold 66 Dart and learned how to do pictures since first post.
Front
Wheel Brand Mopar Police
Size 15 x 7
Backspacing 4¼ inches
tire size 235/60-15
Suspension mods Polyurthane bushings, 75 K-frame
Monroe gas shocks
Police steering box
Rear
Size
Backspacing
tire size
Suspension mod gas shocks, lateral Watts link
The photo is just before it went into the paint booth.:snakeman:
Car year and model
Front
Wheel Brand Centerline Retro
Size 17x7
Backspacing 4"
tire size 225/45/ZR17
Suspension mods .990 Torsion bars, set 2 1/2" below stock
Rear
Size 18x8
Backspacing 4 1/2"
tire size 245/40/ZR18
Suspension mod 5-leaf heavy duty leaf pack and heavy stereo system
Front
Wheel Brand Coys Wheels
Size 17X7
Backspacing 4.5"
tire size 245/45/17
Suspension mods GAS SHOCKS, 73+ disk brake (with the big police rotors) conversion & .890 TORSION BARS
Rear
Size 17X7
Backspacing 4.5"
tire size 245/745/17
71 Duster Dana 60 at 51", mini tub and spring relocation.
15x12 ProStars with 6.5 back space, might need a .25-.50" spacer
30x11.50
70 Dart
245/60/14 on stock rallye
Front
Wheel Brand: Cragar
Backspacing: 3-1/2" (+/-1/8") standard
tire size: 195/65-14
Suspension mods: None (stock drums)
Rear
Wheel Brand: Cragar
Backspacing: same
tire size: 215/75-14
Suspension mod: None
**I had to grind the weights on the drums down a bit 'cause they were hitting**
