2018 Small Block Race...... join the Fun
Posting this up since I'm going to make a few changes while it's hot, humid, and raining everyday.
67 Dart
Weight 3200 -.1
Gear 3:91 -.5
26" tire
sea level
340 -.5
4bbl -.4
headers -.4
IMM LAX -.6
235@.050 -.6
.040 overbore -.4
904 low gear set GVOD
TA 10" 3200 Tight converter -.7
Penalty box -4.2 = 11.7
Ran 11.771@113.70
NICE !!!! Standings updated!
P.S. - nice to see the penalty box work..... Penalty box calls for a 11.7 and the car runs an 11.7 :)
1966 Barracuda
Stock 273 (+.6 )
3.55 gear (-.5 )
Weight 3400 WITH Dany, and the jack/spare so I'm gonna go with 3300?
Want to weigh it with the new wheels to see if it changed, if it did I'll correct.
Penalty box total = 16.0
Pretty close!!!
(have a video, if I can figure out how to post it??)
1966 Barracuda
Stock 273 (+.6 )
3.55 gear (-.5 )
Pretty close!!!
AWESOME!! I added you to the list, and posted your run. I named you DANY, I hope that's alright. If you have a new best, just post it and I'll update. Tell Dany (or show her) she is currently in 5th :)
racers 2018.xlsx
Went 13.86 on my 13.10 dial. Back to the old drawing board.
My crew chief says “we need to spray it dad”!
COOL!! That's good enough to tie ya with Dany (motorpirate) for 5th. I say tune it, your 19 mph pick up the last 1/8 mile is close, but there may be a mph and a couple of tenths there given up! Nice pass, though!
Also, tell us a little about your build.....
72 Duster
‘74 318 .030 over flat tops
2.02/1.60 J heads PRW 1.6 rollers
Comp 280H 230@.050 .480/.480
Torker, 650DP, 1 5/8 into 2.5 ex
A833, Hays S/S clutch, 3.91SG
002/003 S/S springs,
Rancho 9 way shocks
275/60 Nitto drag radials
Leave on the 2-step at 4800
Shift it at 6000.
Have gone best of 13.6.
Needs 4.30 gear and 750 carb to come alive but then it would be less enjoyable on the street. Also, may swap to a little smaller solid lift cam this winter, like the Comp 20-246-4.
I wasn’t sure how much to subtract for my cam because it only has .480 lift but 230@.050”. I went with -.6 because the 1.6 rockers put the lift closer to .500”
72 Duster
Rancho 9 way shocks
Shift it at 6000.
When your tires wear out go to a 255/60/15 27" tire for the track visits.
You also could advance your current cam a few degrees. I run the xs274s in @ 104 ICL in my 340, very street-able.
Enjoy the time spent with your Crew Chief!
Thanks. He’s a total gear-head!
Here he is tuning up his sisters dune buggy.
The thought of advancing the cam has crossed my mind. May try it before dropping the coin on a new one. Just put a fresh set of tires on this year so that will have to wait.
Changed jets, metering rods and timing for last nights Test and Tune. Ruby responded well (16.899/80.66). This is her cam. Should there be an index adjustment? If so, please change my index to 16.2.
Changed jets, metering rods and timing for last nights Test and Tune. Ruby responded well (16.899/80.66). This is her cam. Should there be an index adjustment? If so, please change my index to 16.2.View attachment 1715211092
Nice gain for a carb tune ! :)
Yes, that cam is definitely healthier than a stock 318 2bbl cam, I'll change your index and add your new pass. It moved you up to 5th :D
Good luck, keep tuning :)
A new best last night. Too bad it was a first round loss.
Ruby did her job. The driver however, went red AND broke out. Other than that I nailed it. :-)
Good news and bad news:
Ruby ran a new best last night. I did however stop at the scale and she weighed in at a diminutive 3120lbs. You will need to reduce my index another tenth.
