302 casting potential?
no no no im not saying anything about there not being good info in this thread...i just wanted to see other threads of guys who used them and with combination, what size valves, flow #s, etc....wanted to immerse myself in more info about them that is all, since i know nothing about them...the guy at the show kinda sounded like a goof when he told me to my face that x heads are garbage on my 340, but i dont know anything about 302/308 heads so thats why im asking here...that is all...didnt think i would get in trouble for asking
X no good? I would like that proven to me.
LOL your the second guy now with that...i have always thought that x heads were one of the, if not the best, factory smallblock heads, but that guy tried to tell me otherwise...im just trying to understand the science behind these other heads to see if hes right, half right, or completely wrong
Those are just some 'smog era' 'air port' style heads.
They have the holes in the exhaust floor for air injection, some say air inj bosses provides more floor, but really no significance.
Those heads in that artical made several diff mags, I have it in car craft of like 2002, they max'd out at 253cfm around .550 lift.
I'll dig up the mag.
is that any good compared to what a mildly ported x head can do?
I have 70 x heads 340, 2.02- kicked butt. Have a set of 70 j's, same head. 2.02 Same performance.
Maybe only on a 340?
My mild bowl blend and push rod pinch open up netted 225@.400 & 242@.450 w/my x heads.... so it's really who's porting them.
They did an awful lot and got only lil in my opinion.
It's all about whos porting them.
yes i agree with both those points...considering ive never ported anything before and this would be my first time, im wondering if the 308 heads would even net me over what stock x heads flow...and yes, i read the whole article and agree they did quite a bit of work that i expected more numbers out of
you ever port a set of 302s? theres alot of meat in there. matter-o-fact i broke through the p-rod guides before ever coming
close to the water jackets. brass sleeves and fixed. IMO the swirl chamber is the power maker.
ive never ported anything man lol so im new to all this...i would really like to port a set of heads though as i think it will help understand all this stuff alot better...of course, i need some knowledge before i even pick up a grinder or set of heads
When it comes to the W2 exhaust port reference- I believe due to 20 something years of the same 340/360 low floor exh port, people tend to call any mopar exhaust with a good raised floor 'w2 style'.jmo
But really...They wouldn't come anywhere close to what a w2 exhaust flows.
when you get 1/2 inch tall then layed back type floor from the seat, then you have something 'like' a w2 exh port.jmo
I took a look at the numbers that ryan J has in that link you posed for 302's and J heads, and it seems like the J heads have a decent amount more flow...but flow is not everything right? or alteast thats what i read...and man, i wish i knew what you were saying about floor and seat and stuff lol...i think im gonna look for some sort of cylinder head walkthrough video or something, since i need to understand all these terms and such
When you see a head pick up 30-40+cfm every .100.... Thats fast moving in relation to the cam lift rate and such, and is everything, granted the port volume isn't gargantuan in relation to the bore/stroke size.
And also know that the shady 302 #'s are right at the edge ratio wise 242/142, if that lopp sides anymore the rpm hp turns to crap
I remember a Hot Rod magazine article where they built a 400 hp 318 w/ ported 302's. I still have the issue if you want me to send you the article.
unless you are going all out with this engine, larger intake valves are a waste of time. the velosity will be killed with the larger valves. exhaust valves should be enlarged but that is it. there are many threads on here reguarding "302" cast heads. look some of them up, then if you still have doubts contact or study some info found on "bj's" site."bjr" is the small block expert on here....
http://www.forabodiesonly.com/mopar/showthread.php?t=19556
http://www.forabodiesonly.com/mopar/showthread.php?t=28974
http://www.bjrracing.com/small_block_heads.htm
You better READ THIS THREAD before you start throwing out people as EXPERTS!!!!!!!!!!!!! Maybe BJR in his own mind is an expert but such is NOT THE CASE!!
http://www.forabodiesonly.com/mopar/showthread.php?t=80088
It's pretty safe to say numbers are not everything. In fact, numbers are just that. Numbers. PLotting trends and giving some point of reference for output expectations. Plus, this is the internet. It's pretty easy to say a bunch of stuff and there's no way to dispute it scientifically. Even having someone else test something you can't consider the results to be exactly repeatable, and no flow bench can't tell you how they will work on your combo because it doesnt reproduce the actions inside the running engine.
I don't trust numbers unless they add up with the performance. So "stellar" numbers don't sell me on anything. I've seen too many stock-port-headed cars running fast to believe its' just the numbers. And as I said, anyone can say "I got 'x' for flow". Hughes and Indy do it all the time. I can't count how many times I called into question others' results and got beat up for it...lol. So I'd say you're definately in the majority just going by numbers...lol.
I was there when they were flowed, thats the difference between reality[where I live] and your example.
If you buy heads and don't check them, you are screwing yourself.
Thats just what you should do at this level.
I have a flow sheet for a set of W2 econo's from the 80's that were ootb stock that only flowed 214cfm @25 or 226@ 28
they are advertised to flow 260 or so @.500 or something, so yeah people get ripped, and most never know it...
but they spend a long time disappointed with the performance or lack of.
Wow, now I am recalling why I left this site long ago, got tried of the BJR and others BS.
That is too bad cause there are some great members on here but it gets very annoying seeing BS posts everyday.
Why I spend my time on speedtalk:sign10:
Good thread...old but good.
You can build and tune around a lot of things weather it be Heads, a cam etc...
even make up for lack of hp if you can tune the suspension better than the other guy.
I still wanna see proof of a 318 or 360 w/302 heads making 500+
