My plan is to use KB167 +0.060, 318/340 crank 3.31, ported 974 heads w 2.02, 1.60 and milled to 60cc valves Lunati Woodo 268/276 cam, offenhauser 360 w Holly 600. Am I on track with such set up or off side what do you say?
If you are going with the 2.02 valves, ditch the 360 and go with either an LD4B or a Weiand Stealth, depending on what you are doing with the runners.
If you are leaving them alone like I did, go with the LD4B and the correct Fel-Pro gaskets to match them up, after you have checked and centered your intake.
If you are going to move metal in the runners, go with the Weiand Stealth. It's the same layout as the LD4B, but it has slightly larger runners that are a touch longer. Sort of a midway, between the LD4B and LD340, like the new Edelbrock performer, but with a better layout and better casting quality.
If you buy a new Edelbrock, check it with a gasket for core shift. There have been a lot of complaints recently with front and rear runner spacing changes between runs.
The 600 Holley double pumper would be a good way to go.
