1wild&crazyguy
Banned
Just another data point on costs.
The machine shop I used for my 360 build charges;
$25 each for cleaning, magnifluxing, resizing and installing new bolts plus the price of the bolts for rod reconditioning (ARP Bolts are $60 for a total of $260). They suggested I take a look at new rods from Eagle or Scat. I wound up going with the Eagle SIR rods and saved about $25 and wound up with a stronger rod with floating pins and ARP cap screws.
To have my crank cleaned, magnifluxed, ground 0.010" under size and polished cost $225.
To have my Block cleaned, magnifluxed, square decked, bored 0.030" over with finish honing with deck plates, new cam bearings installed and painted was $800.
Balancing of the rotating assembly was $250, this is a must with the SIR rods and KB107 pistons because they are so much lighter.
I didn't have any machine work done on the heads, they came from a low mileage Durango that spun a bearing under warranty.
holy sht!
why so expensive??
whats weird too is that It costs $600-800 for block work here... but even still only costs $9-$12 a rod for resize.
The pistons are removed, then they hit the solvent tank, then the cap and rod both have .003 removed on the cap facer/grinder, new bolts pressed, then they hit the sunnen rod hone machine and are checked there as well.
It's easy.
To polish a crank costs $45
A balance around here is anywhere from $125-$200 depends on type/metal amount
