68 barracuda tire size
I have a 68 barracuda fastback with 8 3/4 rear end with 5x4 1/2 bolt pattern. I moved my back springs in onto my rails. What is the biggest tire and wheel can I go with including back spacing I like the deep dish look
I run 275 60 R15's on my '68 Barracuda fastback. It has Superstock springs. I could for certain fit 285's and likely 295's. 295's are only 1/4 inch wider, on both the inside and outside. Check out my car in my garage for pictures.
295 60 d15 , 68 fastback , 3/4'' offset spring hangars , front of fender well lengthened to the inner structure/stock contour--------
car is now lower , tire is up in fenderwell about an inch.
Does wheel vintique make a 15x8 sbp 4.5" backspace? In a Rally?
My bad, this question below was asked.
I noted not the 5 on 4 restriction.
I otherwise did look for it but failed to see it at Summits web site. Perhaps a google search or directly to the seller site will help greatly. It would be nice if they did.
