TrailBeast
AKA Mopars4us on Youtube
Well one good thing I made a few bucks so I might be able to get some transmission fluid and some small little things I think I need to get the tranny lines and transmission cooler.
One question I do have is the transmission kit for the low reverse servo has spring they want you to put in there but it also says if the spring doesn't fit you don't have to just leave the stock one in? Well it'll be a song and dance now that I have the damn thing together to get that spring in there. I'll have to take the tail housing off to take the pin out to get the lever out. I'm thinking about just leaving it alone it is just the reverse first gear return spring? What does that have to do with shifting hard?
Sometimes firmer springs not only make a firmer shift, but also make a quicker release because it doesn't take as long for the spring to decompress.
Personally I don't think it's a critical mod for what you need the trans to do.
The statement that "if it doesn't fit to use the old one" tells you how much difference it makes.
