can't pinpoint the leak...
Transmission and Drivetrain Tech
  1. MTmopars
    MTmopars Well-Known Member
    1,034
    68
    Mar 15, 2013
    Montana
    Local Time:
    9:18 PM
    I have a frustrating 727 transmission leak. Under a load fluid as squirting out from somewhere hitting the exhaust and creating white smoke from under the car. I can see where the driver side torsion bar is wet. I just can find from where. I have right stuffed the pan and fill tube. I can't replicate it in neutral to find the source.
    Any ideas where?
  2. GEO
    GEO Sarcasm Inc.
    1,737
    38
    Feb 12, 2012
    Irvington ,Indiana
    Local Time:
    9:18 PM
    The cooler lines are on that side
  3. 67Dart273
    67Dart273 Well-Known Member
    38,642
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    7:18 PM
    Yup. This would be the obvious "place" and very common. Rubbing together........
  4. MTmopars
    1,034
    68
    Mar 15, 2013
    Montana
    Local Time:
    9:18 PM
    Can I replace the steel lines with rubber?
  5. GEO
    GEO Sarcasm Inc.
    1,737
    38
    Feb 12, 2012
    Irvington ,Indiana
    Local Time:
    9:18 PM
    I'd rather have steel ,they may just need to be tightened up at the transmission.
    Make sure they are routed away from the exhaust and anything metal so they don't rub a hole in them
    • Like Like x 1
    • MTmopars
      1,034
      68
      Mar 15, 2013
      Montana
      Local Time:
      9:18 PM
      They are tight. Already checked. They are the original lines but are for a 904.
    • GEO
      GEO Sarcasm Inc.
      1,737
      38
      Feb 12, 2012
      Irvington ,Indiana
      Local Time:
      9:18 PM
      Might need to pull them off and see if the flare is cracked or the fittings that go into the trans may need tightened or sealer put on them.
      Any auto parts stores will have the steel line by that foot that is easy to bend.
      If you go with rubber you have to get higher pressure Power Steering hose , as fuel line hose isn't strong enough.
      And the PS steering hose is a lot more expensive than the steel line
    • Bulldozer
      Bulldozer Well-Known Member
      15,552
      1694
      Oct 16, 2011
      why
      Local Time:
      9:18 PM
      I avoid using any rubber line for the transmission at all costs
    • mvh
      mvh FABO Gold Member FABO Gold Member
      1,358
      146
      Dec 17, 2007
      Menlo Park, CA
      Local Time:
      7:18 PM
      The cooler lines sometimes crack at the bracket that is bolted to the bellhousing. It's metal-to-metal -- it really should have a rubber isolator. My tranny shop refused to put it back on.
    • WRB426
      WRB426 Insane 4 Mopars FABO Gold Member
      2,237
      173
      Apr 20, 2011
      MA
      Local Time:
      10:18 PM
      I don't like rubber lines for anything. Like said before double check the fittings and install steel lines correctly.
      Another thought if the leak is not the lines check the vent.
    • Bad Sport
      Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
      34,612
      13581
      Jun 12, 2010
      The Wolverine
      Local Time:
      10:18 PM
      You might find this silly, but wipe down the trans just enough to get rid of the excess fluid but leave it just wet enough so you can dump some baby powder on it around the area where you think it's leaking. Wrap some paper towel around the trans line in the suspect area and tape it on.
      Take it for a short drive and look for the wet spot.
      No funny jokes guys. :D
    • Bulldozer
      15,552
      1694
      Oct 16, 2011
      why
      Local Time:
      9:18 PM
      Fixed
    • Bad Sport
      34,612
      13581
      Jun 12, 2010
      The Wolverine
      Local Time:
      10:18 PM
      LOL, I knew it.
    • Bulldozer
      15,552
      1694
      Oct 16, 2011
      why
      Local Time:
      9:18 PM
      lol you knew I couldn't resist lmao
    • MTmopars
      1,034
      68
      Mar 15, 2013
      Montana
      Local Time:
      9:18 PM
      As an update...
      I jacked it up today. Once in the air I rolled around under the car and looked for obvious leaks as I was wiping everything down. Looked like a little leak near the speedometer cable and a bigger leak from the power steering box. Lit her up and let it warm up in neutral. Looked under the car and fluid was dripping fast from power steering. That was new. I turned the wheel back and forth and minimized that leak. I called the wife over to watch under the car as I revved the motor up to 5000. Nothing. No smoke, no oil squirting. I got in and revved to 4000 holding the brake in Low. Nothing.
      So I am wondering if this leak is pudding on the K frame and when I get on it the puddled oil drips back on the exhaust.
    • GEO
      GEO Sarcasm Inc.
      1,737
      38
      Feb 12, 2012
      Irvington ,Indiana
      Local Time:
      9:18 PM
      You might have over filled the PS pump ,it gets filled to the bottom of the fill neck ,just enough to cover the gears
    • MTmopars
      1,034
      68
      Mar 15, 2013
      Montana
      Local Time:
      9:18 PM
      I check the pump, it is a newer style from 440 source and has a dip stick. It was way low. I'm guessing I haven't noticed the leak until now.
    • FredS
      FredS Well-Known Member
      877
      66
      Feb 13, 2013
      Arizona
      Local Time:
      8:18 PM
      so you've checked the fluid level in the trans, and its spot on, at full?
    • airgrabber
      airgrabber Well-Known Member
      812
      42
      Feb 17, 2009
      Florida
      Local Time:
      10:18 PM
      There's a whole host of stuff that could be leaking. If you are using trans fluid in your steering gear it could be misleading you. I try not to use trans fluid in my steering box, only power steering fluid, but...I'd degrease/gunk the entire engine, k frame, steering gear and underside of the trans at the local car wash and start looking as soon as I got home from driving it back.
      The trans could be leaking from the valve body seal in the case, the converter seal, the speedo cable, the coolor lines (as mentioned) or it could be the seals in the steering box or pump.
    • MTmopars
      1,034
      68
      Mar 15, 2013
      Montana
      Local Time:
      9:18 PM
      I've been keeping an eye on the trans level. It's good. When I bought the car the motor was out and the original SBM pump was wired to where the battery tray was supposed to be. I thought from casual observation it was coming from the trans because I did have a leak there to begin with. I popped off the pan and pulled the fill tube and used right stuff. During came break in I had a cooler line that was a little loose and dripping. So when I had wiped under the car without jacking it up I noticed the trans cross member and torsion bar on right side were wet. I drove it again and same area was wet. When I jacked it up I couldn't find much wet on the trans. Just a little by speedo and a little on the bottom of bellhousing. But not that I could roll under the car I could follow further forward and the pitman was wet. Following it up I could see it was originating from the steering box. I could also see discoloration on the headers behind the pitman and storing box. With the suspension hanging I started the car in the car to warm it up. Got down to look for leaks and the steering box was dripping bad. I had noticed a light pooling in the area before but assumed it was from when I changed the filter and oil ran onto the K member. The oil from the steering box was darker than I would have expected. In the drips it was a dark reddish brown. It tastes like what was on the torsion bar. Anyway, moving the wheel back and forth a bit and the drip slowed substantially. So I continued with my test. I have only noticed the smoke when accelerating hard from a roll or kicking down to 1st. So I had my wife watch under the car as I revved up in neutral to 4-5k. Nothing. Had her watch the exhaust. Nothing. Repeated with the car in 1st holding the brake. Nothing. At this point I am assuming this is my culprit.
    • jdsduster
      jdsduster Well-Known Member
      1,073
      105
      Aug 5, 2011
      indiana
      Local Time:
      10:18 PM
      it taste like what was on the torsion bar???wtf
    • MTmopars
      1,034
      68
      Mar 15, 2013
      Montana
      Local Time:
      9:18 PM
      Well yeah. Trying to figure out what the fluid on the torsion bar was I gave it a taste. Sometimes when a look or sniff isn't enough, a quick lick will solve the mystery. Lol. No, I didn't lick the torsion bar.
    • AJ/FormS
      AJ/FormS The end is near FABO Gold Member
      15,005
      4149
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      9:18 PM
      Tasting the fluid is often the best way. Been doing it for over 40 years. I try to stay away from battery acid tho....
    • GEO
      GEO Sarcasm Inc.
      1,737
      38
      Feb 12, 2012
      Irvington ,Indiana
      Local Time:
      9:18 PM
      ATF will make a power steering system leak .I run power steering fluid or hydraulic fluid in mine
