mgoblue9798
What would you guys recommend for a valve job on a 440 that will never see more than .450 valve lift or 4500 rpms? Valves are tiny at 1.88 and 1.50. Using 413 industrial heads and fuel economy is primary concern.
I had never heard of him.. just came up when i was researching things.. trying to learn so i make educated mistakesHe has a good rep before the internet came around.
I'm referring to a standard old school basic stock valve job. The only way to get the correct seat width, is with a 3 angle (or more) cut.There are far better valve jobs out there than the standard 15 degree cut.
A little bit here and a little bit there.This is only about what I gained with a 30 degree backcut on the valve.
So why do cams with more overlap tend to make more power?Anything that increases reversion will inhibit cylinder fill.
I ran into this video the other day and i learned quite a bit about reversion and how cam events and seat angles change things.. Of course it's youtube and he could be full of crap though
Curious, do you usually not use a back cut? Where are you at on the .300# and what do you think it should be?I’m struggling with my .300 flow number for the first time in years but that’s for another post. While searching for that lift issue I had a few extra minutes before I quit so I did back to back tests with two brand new 2.055 Ferrea intake valves. I’m sure I did this many many years ago but I keep better notes now so I will add this to them. I had always heard it help low to mid numbers and may hurt high lift numbers but this is the gain from .100-.600 lift.
.100——-+6
.200——-+7
.300——-+8
.350——-+7
.400——-+5
.450———+5
.500——-+3
.550———+4
.600——-+4
What if you need that to improve the vaporization of the mixture because the carb you use produces a droplet size that needs it?So why do cams with more overlap tend to make more power?
I would recommend using different heads.What would you guys recommend for a valve job on a 440 that will never see more than .450 valve lift or 4500 rpms? Valves are tiny at 1.88 and 1.50. Using 413 industrial heads and fuel economy is primary concern.
Sounds like the Speedmasters are a better choice for low lift and lower rpm.I always have used a 30 degree backcut but just did so no backcut testing to pass on and for my records. I took a 45 year break from doing anything for customers because number one I was only charging 400.00-500.00 per job for mostly friends and burned myself out. Of course when you do your own stuff I do more testing and do my own thing. On the new set of 2.08
Valve heads I’m doing for myself I’m at 214@.300 and pushing 328@.700cfm. These heads are to hopefully replace an old set of open chamber heads I’m running that I did probably over 10 years ago. Well the set of Speedmaster heads I just did easily hit 208@.300 the i struggled to hit 190@.300 on a set of used Edelbrock heads that had a little work done to them previously. I was ok with that because he’s running a .645 lift roller cam and they recovered nicely at .350 and ended up over 308 cfm with a 2.055 valve. Now another set of used Edelbrock heads with a little work done and I had to really work at getting him 189@.300 and was trying my hardest to up the lower numbers as he’s on running a .565 cam with the heads again nicely over 300 with a 2.055 valve. That’s what made me look at the chamber of the two heads. The speedmaster chambers are definitely clearanced better than the Edelbrock heads which in turn produce better at .300
Lift.
Gonna give it a shot and see how wrong i am
More overlap allows a better cyl fill which means more cyl pressure allowing more power, up to a point in which reversion would cause more issues and loss of power. Also depending on the combo/port design less overlap would make more power since the ports allow for better cylinder filling with less overlap needed, so having more overlap would cause those reversion issues sooner.
I think that might be correct.. most of it was in the video i posted above though.. There is soo much stuff to cam selection that it's turning into black magic for me.. for my 318 using vizards method i come out with a 109 LSA.. that's bout all i've come up with so far.
Trick flow 190's which are 2.02 intake109 LSA with what heads?
On a 318? Overbored?Trick flow 190's which are 2.02 intake
I come up with 110.
109.81 @ a 030 - 318.
Thanks and i'm not doubting you at all.. i trust your opinion, just figuring things out.. I have decided on manual disc/drum brakes so not too worried bout vacuum or idle quality too much at this point. Kind of funny how "just wanna build a cruiser to drive" changes pretty quickly..Gotcha! Best wishes in your build.
The ram effect of the rushing air flow.So why do cams with more overlap tend to make more power?
