Did you read the Madison's article link that has the dyno tests?
I recently used a set of eddies dated Nov 2014. Tried to pull the valves out and they were all jammed in the guides. Sent them to my machinist who honed the guides, machined the warped decks and did a valve job as several valve seats werent concentric. However i was expecting this as its pretty normal for out of the box heads to be all over the place.
Could have run them as they were but didnt want guides that are flogged out in 20k miles and lost power from leaking valves
We noticed that too with the seals .... they are very snug and it took some fooling with them to see that was just the seals. But we also had a couple of guides with small burrs in them where the valves were still tight in the guides even with the tip of the valve stem below the seals. Not sure if they would have worked out by themselves. Either way, it was minor.If the valve seals were on ...they are hard to pull out...without the valve seals they come out pretty easy...that is my experience...
Have run several sets out the box...
I am willing to be that it is due to less heating of the intake charge, keeping it denser. Maybe we should start the idea that running dry ice in the water jacket helps increase power....LOL!I found it interesting the difference in power at 110° vrs 185° water temps.
justin
I think the proof is evident to anyone successfully running al heads with 11.2/1 Scr or better and cams in the 235* +/- 13* range, and a minimum running temp of 200*F, and power timing of 32* to 36*,and on 87E10.
I doubt anyone would try that with iron.
I can offer no other reason than that the chambers are cool enough to not detonate.So I jump to the Scr, as the most likely answer.
As to a power difference, I can't say, and don't care. Whatever mines got, it's plenty enough for me.
The hotrod.com article? I just read it and it confirms my suspicions that there is no measurable difference from a power stand point, everything else being equal and just changing the head material.
Rumblefish,
You are correct about aluminum heads flowing better than factory iron but now you can get aftermarket iron heads that out flow the aluminum edelbrocks for 2/3 cost. EQ heads out flow Edelbrocks by quite a bit. They will outflow ported Edelbrocks right out of the box.
So these EQ heads flow almost 300 right out of the box? Sorry, I don't buy it.
This is totally misleading. With the EQ's with 2.02" valves, they flow slightly less than the stock Edelbrock Performers except at .400" lift. They are very close in flows across the board with the Edelbrocks having a negligible edge.Rumblefish,
See here:
http://www.hughesengines.com/Index/...biB3LyAiTEEiIFN0eWxlIEludGFrZQ==&partid=27826
and here:
http://www.edelbrock.com/automotive/mc/cylinder-heads/chrysler/performer-rpm-sb.shtml
With a full spring kit, the EQ's with 2.02' valves and their installed valve spring kit run around $1421 for a pair, including shipping here to VA. With the Autozone discounts that you can get, the Edelbrock 60779's complete are around $1422, shipped, and with 5% sales tax paid. This is HARDLY 2/3 the cost.....but you do have to time your purchase to catch the AZ discounts to get this Edelbrock pricing; the Hughes EQ prices are everyday prices.
That 'very little work' appears to cost about $800.....As said, those numbers are not for the basic EQ heads that are in the same price ballpark as the OOTB Edelbrock RPM Performers.... you're comparing the upper end, highly ported EQ's that cost a lot more like the 2.055" intakes or the Stealths.I was using Hughes flow bench numbers for their Stage I port on the Edelbrocks, and comparing it to stock EQ(over 250). Not sure where you got 300 but with very little work, the EQ's will flow 277.
Plenty of head porters can get mid high 290s out of a Edelbrock with some claiming closer to 310. My Edelbrocks went 294 with a 2.02 valve, when they were freshened I had a 2.055 valve put in them. Curtis Boggs did the port work.
As mentioned the EQ head is good for it's intended purpose, but it doesn't have the HP potential that Edelbrocks do.
My RHS Heads flow 294 too. And Usually cost less to port being Iron.
