Duane
Yes it is done, but the recommendation out of the old mopar catalog says 12:1 maxMy alky 383 small block ran 1008's with 13 1/2 squeeze
Cometic is the way to go or more bolts on the head.
Maybe try a cometic with somecompression is 11.8 to 1....fuel is E85.....studs were torqued down to 105 with arp lube...
pistons...valves...all look good....
Yep, almost 12 to 1 might be pushing the limits.compression is 11.8 to 1....fuel is E85.....studs were torqued down to 105 with arp lube...
Cylinders 3&5 are also the cylinders with the side by side exhaust valves so that part of the head and block is hotter.From what I can tell from the pics, it doesn’t look like heat burned through the fire ring.
It looks like the fire ring wasn’t holding a seal, and the escaping combustion gasses torched the paper/rubber part of gasket that’s out past the fire ring.
It’s a common area for a SB Mopar head gasket to fail since it doesn’t have a lot of area to be squeezed between the block and head, so it doesn’t have a very good way to transfer/dissipate the heat out of the gasket body into the block and heads.
The material the Cometics are made of will be able to withstand the higher temps better.
Fundamentally, I think it’s likely a tune up issue.
Whether that’s from a faulty timing light, weak fuel pump, bad batch of fuel, etc..... who knows.
But I think a Cometic would have a better chance of surviving it.
That would be pretty noticeable, up on teardown more so..Might have got pushed out if it hydrauliced if any water got in those cylinders
Head gasket removed from 410 engine ....cylinder 3 and 5 show the gasket egg shaped...cylinder 1 the fire ring was detached from gasket.....any clues?
engine is flat top zero deck 410 cubic inches...with ARP studs....close chamber eddy heads...
Here is a link to a custom cometic head gasket that I had made and anyone can buy.Head gasket removed from 410 engine ....cylinder 3 and 5 show the gasket egg shaped...cylinder 1 the fire ring was detached from gasket.....any clues?
Unless OP has massive dynamic cylinder pressure, Ima thinking that this is a massive pressure issue from some other source, such as preignition/ detonation, and 140 ftlbs isn't gonna solve this gasket problem.
While 34* power-timing sounds about right, if perhaps 2* high for the Eddies, mine does not arrive until 3400 rpm. In this way I can burn 87E10 full-time, and my engine has never burned anything else, at the aforementioned 185psi.
Not to discount your comments here, but the sbm has always had trouble with head gaskets at very high compression ratios around the 12:1 point.Unless OP has massive dynamic cylinder pressure, Ima thinking that this is a massive pressure issue from some other source, such as preignition/ detonation, and 140 ftlbs isn't gonna solve this gasket problem.
Well that will drive your pressure right thru the roof. With an Ica of 55*, Mr. Wallace says 210 psi. That counts as massive for pumpgas; IDK for E85; but the 1008s sure seem to be overwhelmed.hughes 264/268 -108 ....installed at 104
Good luckthanks everyone.....everything is cleaned and ready to go back together....due to time constraints...I am going to use the 1008 head gasket again....and address the problem later this year....
Good read here on head gasketsHead gasket removed from 410 engine ....cylinder 3 and 5 show the gasket egg shaped...cylinder 1 the fire ring was detached from gasket.....any clues?
Watching.
