How much power is lost through a 518
Transmission and Drivetrain Tech
  1. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    63,310
    35963
    Jun 7, 2010
    Georgia
    Local Time:
    2:51 AM
    Splittin hairs. Put the 518 in it and gear accordingly.
    • Like Like x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      18,863
      6882
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      1:51 AM
      Here ya go
    • MOPAROFFICIAL
      MOPAROFFICIAL FABO Gold Member FABO Gold Member
      6,212
      5149
      Jun 1, 2016
      Beach
      Local Time:
      11:51 PM
      Small blocks 340/360 get about the same mileage it doesn't matter what you do.
      If you veer from stock cam into performance cams... the mileage just goes down at a certain point.
      15-17mpg.
      318, little better .now Slant 6... 40 mpg ,mother f'r, just ask any slant owner. Lol jk
    • rumblefish360
      rumblefish360 So close, yet so far away FABO Gold Member
      38,712
      10309
      Jun 21, 2005
      New York, on a Island
      Local Time:
      2:51 AM
      Used all my slant 6’s for sinker weight when I go fishing.
    • mbaird
      mbaird mbaird
      6,129
      3002
      Dec 10, 2005
      boise, Id
      Local Time:
      12:51 AM
      Ok. I got it now.
      Referencing the fast idle cam made it come into focus.
      • Like Like x 1
      • RustyRatRod
        63,310
        35963
        Jun 7, 2010
        Georgia
        Local Time:
        2:51 AM
        But you're right. Slant guys who got 35 plus MPG are around every corner. Just wait. One will be along any minute.
      • AJ/FormS
        18,863
        6882
        Jan 19, 2014
        Local Time:
        1:51 AM
        I have never ever been able to get a slanty up to the numbers of a hi-compression 360, even after I took it apart, and boosted the compression up to a true 9.5. And spent way too much time sorting the combo. Total waste of money and time....... compared to what I got out of my 367 .
        Check out TBs post. #15
        Smart cookie that TB
      • RustyRatRod
        63,310
        35963
        Jun 7, 2010
        Georgia
        Local Time:
        2:51 AM
        We've already figured out your 367 is at the top of the heap. Just ask you.
        • Thanks! Thanks! x 1
        • rumblefish360
          38,712
          10309
          Jun 21, 2005
          Local Time:
          2:51 AM
          Good point. After all, 38 mpg’s out of a Hyd. roller cam @ 224@050 that revs to 7K in that is amazing. Even runs on Yak piss 87.
          • Like Like x 1
          • AJ/FormS
            18,863
            6882
            Jan 19, 2014
            Local Time:
            1:51 AM
            32mpgUs,and it was a FTH cam, and it was a 223@.050.. Try to keep up. TBs at
            25mpg @75/80mph @2100rpm, how is
            32mpg @65 a stretch@1600rpm?
            From 25 to 32 is an increase of 28% mpgs, and from 1600 to 2100 is an increase of 31% rpm; I don't see the big deal.
            I believe TB cuz I know it can be done.
            Like I keep saying; just cuz you can't do it doesn't make it impossible.
          • rumblefish360
            38,712
            10309
            Jun 21, 2005
            Local Time:
            2:51 AM
            But AJ, do t you know everybody gets 35+ and 7K tire shredding event’s with there stuff?!?!
            Building a mileage master is/was a challenge I always wanted to try.
          • CudaFactHackJob
            CudaFactHackJob FABO Gold Member FABO Gold Member
            1,290
            440
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            1:51 AM
            Over the years I've read a lot of posts stating that a larger transmission robs huge amounts of power. I actually read that a C6 takes 60 horsepower away. Here's the flaw in the thinking and observation. A 727 is going to most likely come out of a larger car or a truck. They utilize a lower stall converter. If you put that into a lighter car, it will be slower on takeoff; just like a th400 has a larger converter than a th350, a C6 has a larger converter than a C4. With the same stall, the big trans won't produce a noticeable difference in the seat of the pants; only in a fraction of a second on a time slip.
