So, just recently I've been reading up on small blocks and how to modify them as I'm trying to expand my knowledge and experience. For Christmas, I got a couple car related books and lately I've been reading up on "How to Rebuild Your Small Block Mopar" and "How to Build Big-Inch Mopar Small Block." Looking at these, a small block stroker engine may not be a bad, future option in my Dart. Going through these books, I'm learning quite a bit. Now I sort of understand why the 340 is more desirable than a 360.
So, here are the requirements. Car is going to see a mix of street, mountains roads (Glendora Mountain Road is about 5 miles away), autocross, and road racing. I'd say most of its time will be on the streets, maybe once or twice a month in the mountains, once or twice a month autocrossing, and once or twice a year road racing. I'm not going to get into anything super competitive, yet. It's not going to be a dedicated race car. It would need to run on California's 91 octane (as other octanes are practically unobtanium or super pricey). Since this is going to be in a handling car, the lighter the better (an aluminum block seems like overkill, no?). And I care about reliability, a lot. I'd like this engine to last for years to come. Let's just say the budget (carb to pan) is $10k (the cheaper the better, but that seems reasonable, right?). How would you build this stroker?
So, I guess here are my questions...
-How much horsepower/torque would you suggest I need? I'd imagine a fairly flat torque curve would be desirable as I will be constantly slowing down then accelerating.
-What block would you use? 360, 340, R3? So, from my understanding, a 340 is essentially a 360 with a 3.310" stroke and a +0.040" overbore.
-What crankshaft and stroke would you use? 3.580", 3.790" (apparently a couple companies offer it), 4.000"?
-Would you bore out the block? If so, how much? What pistons would you run?
-What heads would you run? Is there a benefit to running W2 heads over (lets just say) Edelbrock Aluminum heads?
-What intake and carburetor would you use? Single or dual plane? Aluminum intake preferable?
-Would you use cast or forged internals? Which parts would you choose to be cast or forged?
I'm curious as to what you guys think or what you would build?
