RustyRatRod
Caput villa stultus
So much misinformation. I think there's someone who needs to completely relearn what ported vacuum advance is all about. What a train wreck. To the OP, good luck!
The chrysler distributors can have a many different advance curves. I don't know how close one for a '75 might be to '73, and the one you have might be a generic parts store replacement, or if lucky a Mopar Performance version.these graphs are awesome. And yes, I understand what you say about the distributor and how I'm already seeing mechanical advance at my idle speed.
I'll have another look at it tomorrow, but I think my distributor is an OEM style one. If this is the case, could I correct when my mechanical advance comes in with heavier springs? Or will I need a different ditributor?
That looks like a problem for car that ought to be using vac advance, BUT that may be jumping the gun.
Not enough info here. What's the timing below 2000 rpm? What's the slowest idle speed attained with the engine warmed up? What is the drop in rpm when placed in gear?
You have to start with the idle and off idle. Only time this can be somewhat ignored is a drag race only car. It still has to be somewhat right because the longer it takes for the engine to get what it needs at lower rpms, the longer it will take to get the combustion correct as it moves to higher rpms.Mechanical advance starts coming in at 1700. So up until 1700, it's still 19 degrees. Lowest idle speed is 1200 in park and drops to 900 in gear, which is an improvement from the 1000 rpm drop I was experiencing before I made any adjustments.
Additionaly, I have another problem elsewhere that might be the culprit behind all this. Yesterday I used the car and it stalls under light throttle. Made another thread on it. Wouldn't surprise me that whatever is causing that is also affecting my idle quality.
Great Post once again from Mattax.
