Mopar vs Chevy 383 showdown
How do you guys think that 383 Mopar (actually 394ci due to the 0.060" overbore) would fare against an equally prepped stock bore 396 BB Chevy?
5 hp Honda vs 5 hp briggs equally prepped. what's equal ?
The 396 would romp w/it's head flow,unless the valve size & porting were allowed
on the 383 to match,then not so much. Better yet, lets see how they do w/o any lifter
bore correction or other specialty machining. I've seen no less than 5 of the 396/402
units that eat lifters & cams faster than you can save the money for their replacements.
No, don't give me any ZDDP bullshit, they are notorious for the lifter bores not aligned
w/ their lumpy-*** partners. So much so that the lifter bore correcting jig by BHJ was
machine shop fixture #1 if you plan on running a BBC. If allowed 2.18/1.81 valves, I
wouldn't throw the 383 under the bus, that's a fact.
Rollers or no, the lifters won't last if they're not squared up,My 383 will still be
running 10 yrs. later w/o the unhealthy appetite.
I vote next build-off should go as follows
318 +.040 (325ci) Mopar VS 327ci chebby
9.5:1 comp
air gap intake
similar spec hyd flat tappet cam
1-5/8" headers
for cylinder heads I reckon double humps vs 915 J's. both with a nice valve job.
Hit up the dyno and run the numbers.
THEN port those heads to the max and run them again!
As for the 396, I raced a 70 396 chevelle leaving a car show in my dads 383 coronet, the 383 was cam, intake, and headers. I don't know about the 396 but whatever it was it got beat lol
LMFAO..396 handed many of them they're arses with a 340..lol
One of my brothers is a big Chevy guy. He has had a few 396's in Chevelles and one that was built in a Camaro, and every one of them have been dogs. By my seat of the pants I would guess 15's in the 1/4. That's just been my experience with what he had.
Too many variables on the 396. HP anywhere from 265-375. Most SS Chevelle's were 325 versions if IRC. 375's were pretty hard to beat. Built the same, going with the Chevy motor, much as I hate to.
Lol, I have watched 396 chevelles run 16's, but I've also watched 440
satellites run 17's. Too many variables indeed, mainly the people involved.
