shouldn't be long once that 408 is in :burnout:
Haha, that's what I was thinking!:burnout:
You're right, I just ran some calculations online. I'm going to go with 3.23 and eventually change the rears to 27.8" tires on the next set.
Well the stroker kit has shipped from scat. It'll arrive Friday but I'm in sunset beach, NC for the week so it'll have to wait to go to the machine shop.
Maybe I missed it. But what did you end up on deciding for heads? I have iron heads on my +.040 over, 10:1 340 setup, worked, 2.02 intake. And the builder rated this setup for just shy of 400 horse on exhaust manifolds. I'm also running the XE274H cam. Everyone thinks you need alum heads to make good compression and great power. But honestly iron heads are a tried and true way to go, and with a little work lots of folks have seen the same flow and abilities as those 2g+ alum heads we all drool at.
Better have a neighbor keep an eye out for it. Summit left over $3000 worth of parts on my front porch when I bought my stroker kit and cylinder heads.
Mine ended up .010 out of the hole. Machine shop gasket matched 596 heads. It happens, there is all manner of easy fixes - fatter gaskets ect. It will be likely you'll have to cross that bridge when you get to it. No amount of thinking ahead is going to make sure the pistons are one way or the other. Decking and squaring things out though is doing it right. It could just come out to them taking off an amount of material that causes pistons to protrude to make things right.
I had never been down this road before this last winter. if I had to do it over again I would have took just a little bit more time as I'm one of those Jim Morrison kind of guys who wants to world and wants it now. If the Pistons protrude they can be milled down a bit also. It's just a matter of taking more time and a little bit more money, but in the end I can't say this enough that when you get in the car and mash that pedal down you'll never think of a penny spent.Thanks again j par, you've been a big help. I guess I was just worrying a bit, never been down this road before.
