rigger3006
ah... i stand corrected!
I believe the problem was there before the box. I have not thrown any parts on it as of yet. It is still a fun car to drive right now. If it had single valve springs then I could stay with the worn valve spring theory. Seeing the doubles with a damper inside makes me think they should be overkill even if worn out a bit. Mopar specs a single valve spring as one that goes with the cam. It is no longer available though. I really think we are going to find either a pick up coil problem or a rotor phasing problem.
I just went out to check it the car tonight. I found a couple of things. Nothing that seemed to make a difference. The phasing did seem off by quite a ways. The clocking of the distributor drive gear was off a couple teeth from factory. I reset and reinstalled the distributor. One problem. The tach drive now hits the intake . I disconnected the tach drive and set my timing at 34. Cranked it up still breaks up at high rpm. Didn't have a tach so was doing it by ear. I bumped the timing up to 40 by accident. It liked this for idling but didn't help the breaking up. I forgot to bring my vacuum Guage home so will try that tomorrow. Oh and the reluctor gap was .008
The problem was when I rotated the timing mark approx 34 degrees before TDC the rotor was actually closer the number 8 terminal than the number 1 terminal. I was attempting to get the rotor closer to number 1 to prevent spark jump.You can't clock the drive gear by a factory anything. You look at where the slot is when the rotor is pointing at number 1 on the cap. Then you clock the drive gear. Otherwise, you break the tach drive off, or the vacuum advance can if for some reason you think you should have one.
I've cut the top off an old cap before just to see where the rotor was pointing when it was firing. Amazing where some Dizzy's are pointing.The problem was when I rotated the timing mark approx 34 degrees before TDC the rotor was actually closer the number 8 terminal than the number 1 terminal. I was attempting to get the rotor closer to number 1 to prevent spark jump.
Roger. I would not be suspecting reluctor reversal with steady timing.Timing doesn't change at all. There is no vacuum advance on this distributor.
Also I should clarify. The distributor advance is not actually locked per say. The springs are so light that it is all in at idle speeds. For my testing with a timing light it is 34 at idle and at WOT
At what RPM are you spinning it during your burnouts? Above 5200? No popping?
If so, I'd look at the fuel system.
I actually used a stock distributor for the last couple years and just blocked off the vacuum advance and used only that centrifical advance. it worked almost exactly the same as the MSD. Now the MSD setup the starts better and stuff like that but I don't think I gained anything in the quarter mile that I can see so far. I was going to suggest an inexpensive stock distributor but I have a hard time cyber spending other people's money. But I agree this is a good starting point and not that expensive. I think I paid like $68 Maybe for mine brand new.
The distributor I found on Craigslist locally. He is selling it for 30 and it was originally part of a kit. He told me that he is using an MSD distributor now.I did the same in my setup. I ran the stock reman/recurve I have with my box. I have a new distributor now, but it's still the old mopar/mallory style. Nothing wrong with them. They work great. I doubt you'd give up anything to an MSD in the quarter. With breakup distributor is always a good bet. And if it isn't that. Well hell you can always use a spare around the shop anyways.
Try the gap at 8-10, make sure the rotor is phased correctly. And let us know. I am still very interested in what is causing this.
