You wanted to know about how to measure at the rocker and find out your lift. Your worried about lift. You mentioned not getting the full amount and mentioned the deflection loss.
To get what your missing, the full 1.5 ratio amount, you need a good rocker, just one & a solid lifter with the correct length pushrod. Put the dial indicator on the valve too and measure up.
A .508 lift cam is a low lift cam and there should not be a clearance issue with stock valve train or piston, aftermarket or not. If there is, I would check how the cam is installed.
Using a better rocker for the full lift of the cam installed as so to get what you paid for is something everybody I would think everybody wants.
Do the math of the rocker ratios on your valve lift. Be aware that some of the OE stamped rockers can come in under 1.4.
