Post your wheel and tire combos.
it looks like these wheels
Ridler 695 18x8 5x114.3 0mm Grey Wheel Rim | eBay
I would guess 18 up front 20 in the back. .
Nothing that hasn't been done before, but it's mine.
1969 dart
OEM mustang 17x8 bullets all around.
Front:
235's would like to go up to 255's soon.
Lowered with 1.14 bars
Stock 69 Lowers
73 uppers and knuckles
Córdoba 11.75 brakes
3/8 spacer to clear hub and tie rod end.
3" studs with open ended lugs.
Rear:
245's would like to go up to 255/45r17
Full width 98 explorer rear end moved back 1"
Mancini HD springs
1.25" adjustable lowering blocks
Will a wheel with just over 5 inches of back spacing fit a 74 dart swinger all stock?
Will a wheel with just over 5 inch of offset fit a 74 dart swinger all stock?
5" of backspace you mean? 5" of offset would be pretty crazy, and totally different than 5" of backspace.
Depends. If the rim is at least 17" in diameter, then yes, a wheel with a bit over 5" of backspace will fit in the front. If it's 15" or smaller not a chance. In the back it will depend on the rear axle, if it's an 8 3/4 with the large 5x4.5" bolt pattern axles you'll probably need a small spacer if the springs are in the stock location. If it's anything else you'll need a fairly large spacer, probably over a 1/4" thick.
What wheels are we talking about?
Currently running 215/70/14 Uniroyal's that are old but barely worn. Really wanting to upgrade to a 15" Mach 500 wheel with some nice rubber in the future.
There are a lot of cars in this thread with nice aftermarket wheels on them, but I'm still a fan of body color wheels and dog dish hubcaps! Haha
15x7 Cop wheels/caps. 255/60/15 rear and 215/65/15 front Cooper Cobras.
Below is my finished combo. Stock suspension all around, 15" X 6" in front with 235-60-15, custom made backspace 15 X 8 in back with 275-60-15 in rear. Both are tight but both work well. The 275's will be a gift with my 3:73 ratio rear axle. Got my front end alignment today as well.
74 Duster rear cragar ss
275/60/15 bf Goodrich15x8 wheel
Rear has room to lower car if wanted
Ft cragar ss 15x7 215 60 15
This is my 73 Duster with a comparison between 14" and 15" wheels. The top pic is 225-60-14 front and 235-60-14 rear, the bottom is my new setup, 215-65-15 front and 255-60-15 rear. The front wheels are 14X7 and the bottom setup is 15X7 front and 15X8 rear.
72 Swinger ... 318 automatic 7 1/4" differential 45 yr old stock leafs (for now)
front
14 x 6 Wheel Vintiques 195 75
rear
15x 8 Wheel Vintiques 4 1/2" backspace 245 60 ... 40 lbs in the Hi-Jackers
front
rear
67 barracuda 5.7 Hemi 545rfe trans. Alterkation front suspension. 8.8 rear with leafs. Front American racing 17x8 cooper tires 250/35/17. Rear 17x9 cooper. 275/40/17
How did you you know I am a "former" desert rat? My Dart 15x8 Wheel Vintiques are 4 1/2" backspace.
About an inch to the leafs with 245s on it.
I do not know the back spacing I will pull the wheels off today and check. They did rub the front of the fender and had to trim a bit. After I changed to the Alterkation. I had to add a 5/16 spacer to the rear wheels to move them out. They sat too deep and looked funny after ha being 255/50/17 on before but I could not find a tire 275/50/17 that I liked will never buy the Riken Raptors again. They have no traction on wet roads.
