I think I found where the map light goes. Is it to the lower left of the steering column? I have the dash-mounted bezel for it but I don't see the switch or bulb at the moment. Does anyone have photos so I know what to look for or replace? And where does the light itself go? Also, no fender turn signals or wiring to be found on this car.
Slow progress the last few days, but I did manage to get the fuel pump replaced. Since the car sat for 25 years I am re-doing all the fuel system, including the hard line from the pump to the carb. I got a piece of brake line to form into the new line but it wouldn't bend nice using the bender tool I had. It started to kink so I had to figure out a better way. Then I noticed this.
Old black line on the right, start of the new line on the left. Hmmm, I wonder how I'm going to tighten the nut down on the pump, it seems to be stuck on the back side of the bend. And how to remove the upper nut that I don't need?
Off to Napa for another one. I dug around and found my set of spring benders which worked way better. I also got a much longer line to start with so there was some leverage to work with. This stuff is pretty stiff. I only need a 20" run so that's what I got the first time around. The second try was only a dollar more for a 40" version which really helped. To hold the thing still I clamped the old pump in the vise and worked the bender while my girl provided power to make the bends. It worked like a champ. Then, of course, it was test fit, bend, test fit, bend, and so forth for quite a while getting this just right.
It's funny, the new line fits MUCH better but isn't all that close in shape to the old one.
However, success! Line is in and new hoses and filter are set.
One more (stupid little) thing to check off the list. After getting the fuel pump sorted out I went back under the car with the needle scaler to go after the undercoat and crud. Many thankless hours later I emerged a filthy mess but I'm down to just 24" more to go to get to the t-bar crossmember where I will quit for this part of the adventure.
