Mattax
Just the facts, ma'am
Tim, might those be the tubes you need? The vents look like 67 up but the tubes I dont know.I believe he was....
I just sent a note asking about lengths.
Mine took considerably longer than promised when I had the front seat done...Upholstery shop, the OTHER jail for old cars....
Can't beat the price.Tim, might those be the tubes you need? The vents look like 67 up but the tubes I dont know.
That's what she did..I just sent a note asking about lengths.
I should see Joel late this afternoon. I'll tell him about your project and that you'll call.Mine took considerably longer than promised when I had the front seat done...BUT, I was VERY happy with the final job.
if tim thinks they are what he needs I'd prefer he grab them direct.Can't beat the price.
The second time I had the seats done, I borrowed a bench seat from @Rob_Mopar and continued driving the car.Mine took considerably longer than promised when I had the front seat done...BUT, I was VERY happy with the final job.
Gang up on the fat man and roast him out. https://www.mnn.com/earth-matters/a...eybees-sacrifice-themselves-save-hive-hornets
Keep an eye on the sky. This is a fast moving system, and it looks like its heading your way.I should see Joel late this afternoon. I'll tell him about your project and that you'll call.
originally, he was going to make a cover and I was going to install. Just cause I was trying to do everything possible myself. So, he took measurements and I still had my seat. But when near done, he decided he needed the seat to get it right and ended up with it installed for not much more than original quote.The second time I had the seats done, I borrowed a bench seat from @Rob_Mopar and continued driving the car.
I’m curious to see what effect they have on your temps.Did kind of a test fit to block off the open space. I’m no metal magician that’s for sure, but it just may work. Trying to force the air to go through the radiator. Couple of before then after.
The hood to radiator seal is most important...you want ALL the air in front going thru the radiator. Without that seal, a bunch goes over the top of the radiator..I’m curious to see what effect they have on your temps.
AGAIN!!!Got it hangin..View attachment 1715521983
I know about the hood to radiator seal importance. Was talking about all his little flaps/trap doors. Cool ideas and I’m curious to see if there’s an effectThe hood to radiator seal is most important...you want ALL the air in front going thru the radiator. Without that seal, a bunch goes over the top of the radiator..
'67 close upI am.
Those look too short and might be ruberized fabric. So maybe they are for an A/C heater box or a '66.
Guess I can send the seller a question on lengths.
This is the one we decided was for '66 and earlier inbetween the '67 ducts from my car.
