1975dartswinger
Active Member
To answer an older question, the 465 hp 410 stroker costs $11,500. And the 540hp 440 stroker costs $11,995 (single carb).
1st ever that dont leak, ebay , racing junk ,about $150.00[/IMG]![]()
I'm weighing my options here. I'd like an honest answer from some of you stroker smallblock guys as to what it really cost to build your engine, from oil pan clear up through the carburetion system. I'm trying to decide whether to just build the 340 I have, build some sort of stroker engine, or bite the bullet, sell the 340 block, heads, crank, etc. to offset the cost & buy my dream engine as a crate motor from Mopar performance. They have a 410 cu. in. 465 horse stroker that makes me drool.
What's with the recent revival of 4+ year old threads? :wack:
I don't know. It be interesting how well those 5 year old strokers are still running today ?
Why not just build a BBM if you want over 400 CI ?
I guess that's what happens when a message board search feature works real well.
On other boards people complain that people are asking the same questions over and over. So here someone went to effort of search for topic. I have to commend them for that.
But IMHO, the question of a 360 block being able to used with a Hughes 426 stroker kit is really a seperate subject. And should be in a new thread.
1plydust only has 54 posts
Magnum 360
Scat 4" stroke crank
Scat forged I beam rods
Diamond flat top pistons (11.8:1 compression)
Total seal rings
Engine Pro main, rod and cam bearings
Fluid Damper
Cloyes double roller timing set
Cometic head gaskets
Edelbrock Performer RPM heads, gasket matched and ported
Smith Bros. push rods
Comp 1.5 ratio shaft mount billet roller rockers
Competition Cams camshaft:
242/248 duration@ .050, .3660 / .3630 lift @ .050 112 degree lobe sep. 549/544 gross valve lift
Comp valve springs, retainers, keepers and locators
ARP head studs and bolts throughout
Melling high volume oil pump
Edelbrock RPM intake
Edelbrock 800 cfm carb
MSD Pro Billet distributor
Bronze distributor gear
Mopar Performance MSD 6 ignition box
Taylor wires and looms
NGK plugs
Adjustable rev limiter
Mopar Performance valve covers
TTi step headers
2 1/2" custom exhaust with Flowmaster mufflers
All parts and labor, and the labor was done at a machine shop, just over $10,000. That includes intake, carb, headers, exhaust, distributor, ignition, etc ...
